When going into reverse the lights dim?
Old Apr 28, 2006 | 05:38 AM
Mikelikes2drive's Avatar
Question When going into reverse the lights dim?
Is it just me? or maybe just my car, but the lights go a little dim or seem to almost sputter when I shift into reverse? (i have a 6mt) weak battery? or me being paranoid? thanks :D
Old Apr 28, 2006 | 05:58 AM
Rootski's Avatar
DGAF
Probably due to the white reverse lights coming on. The battery can only take so much load, so the more lights that are on, the dimmer each gets. Still, you make look into the battery/starter TSB if you don't have it yet.
yiksing's Avatar
the giant tastetickles
I guess its normal after owning a car for a while, my daily driver would vibrate a bit (due to low idling speed) if I held the brakes when its in D. The ECU senses the engine is about to die and kick up a few hundreds of rpm and the car is ok again. Its annoying but that's life.
Old Apr 28, 2006 | 08:39 AM
Low Fly'n 8's Avatar
Have you got the new replacement battery yet?
Old Apr 28, 2006 | 12:13 PM
KYLiquid's Avatar
Oil Injection
is this WHILE you are backing up, maby you are putting to much load on the engine at a slow speed and its lowering the engine RPM.....do you notice a lot of vibration when backing up?
Old Apr 28, 2006 | 12:21 PM
Razpewton's Avatar
FREE ADVICE!
I don't know about the lights, but when in reverse and the RPMs are sustained above 9,000 for anything longer than a couple miles, mine starts to shake a little....
Old Apr 28, 2006 | 12:27 PM
prescriptionmazda's Avatar
FULL FRONTAL ...downforce
the answer is, "only slightly, only slightly."
theblinkof
Oct 4, 2023 05:24 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
