Replace spark plugs at 30 months with low miles?
Old Apr 27, 2006 | 07:18 PM
LITIGATORX8's Avatar
Question Replace spark plugs at 30 months with low miles?
Would you replace your spark plugs at 30 months (per maintenance schedule 1) even if you only had 5,600 total miles?
Old Apr 27, 2006 | 07:31 PM
expo1's Avatar
He's as bad as Can
30 months and 5,600 miles, stop posting and go for a drive. I can do 5,600 miles in less than four months
If you have not flooded I wouldn't replace them. You can at least take a plug out and post a photo here for us to look at.
Old Apr 27, 2006 | 09:50 PM
Huhwha's Avatar
30 months and 5600 miles, I'd sell it to somebody who would enjoy it.
Old Apr 27, 2006 | 09:57 PM
aggietiff28's Avatar
Mean Green Keeny Machine
Clean them...don't worry about replacing them. You definitely haven't used them enough!!
Old Apr 28, 2006 | 01:50 AM
Ole Spiff's Avatar
The scheduled replacement miles is 37,500 and like everybody has told you, you need to drive this car! 2 1/2 years and only 5600 miles??
Old Apr 28, 2006 | 05:36 PM
What's wrong with that?
I have mine for 21 mnths and 8000 miles
Old Apr 28, 2006 | 06:16 PM
There's nothing wrong with that. My schedule only permits me to drive it on weekends. I have 2 other vehicles that are used for work, errands, etc. I live in the Pittsburgh area so it doesn't go out of the garage all winter. Believe me, when I do drive it, I savor every minute.
Old Apr 28, 2006 | 09:39 PM
grapes's Avatar
I'm sure you do savor every minute of driving. I have 4,000 and just got my plugs, battery and starter replaced per the TSB. Didn't really need it but it was free. The battery and starter would have done the job.
Old Apr 28, 2006 | 10:50 PM
Nubo's Avatar
Lubricious
It wouldn't hurt to inspect them. The simple act of removing them occasionally will help avoid having them seize in place and become impossible to remove (due to dissimilar metals). It will also give you a chance to apply a small amount of anti-sieze compound to the threads to further reduce that risk.
A coating of dielectric grease where the wire boots sit on the ceramic part of the plug will help prevent the boots from heat-fusing to the plugs and helps keep out dirt and moisture.
Old Apr 28, 2006 | 11:26 PM
musclecarconvrt's Avatar
Just for balance, I have 51k on my RX8 in just over two years. The miles pile up kinda quickly on the highway with a long commute. I replaced mine at around 40k miles and man were they fried. Definitely do it at 36K (what's in the book) or before. Nothing like having whole clean electrodes to smooth out the revs and put the power back in.
Old Apr 28, 2006 | 11:37 PM
MI_FamilyMan's Avatar
Sold on Rotaries!
I have had my 8 for 20 months and have not hit 6,000 miles yet. I don't drive much in the winter and very rarely to work (no road trips yet). So it's definitely possible.
I haven't replaced my plugs yet, but I plan on getting the starter and plug(s?) done on the TSB.
Old Apr 29, 2006 | 10:00 AM
msrecant's Avatar
Hubble has been saved!
Since you have had the car 30 months it means it is a mid 2003 build. The main reason for replacing the plugs is to get the new plug design. I would recommend asking your dealer for the "Engine cranks no start" Service Bulletin updates (battery, starter, leading plugs) while the car is still under waranty.
Old Apr 29, 2006 | 10:20 AM
army_rx8's Avatar
X-Sapper
^agreed i had that done..nothing was wrong with my car...i just wanted a new battery and starter befor my warrenty ended i've reeplaced my plugs twice...(they looked fried but not dead both times)...i have 51k+ and she is a 2003 build she likes to drive.
but you have a point about the pitt area..winters don't give you much chance to drive our car. my girl goes to school there...all thoughs damn mountains are fun in the spring/summer...but are brutal in the winter
rotorsnsaabs
Aug 26, 2015 08:21 PM
Zank300
Aug 26, 2015 07:40 PM
cschoeps
Aug 6, 2015 12:44 PM
thedragonrotar
Jul 22, 2015 08:46 PM
Belalnabi
Jul 17, 2015 07:48 PM
