**My 1st somewhat major problem!**<--Transmission
Old Apr 26, 2006 | 11:02 PM
jryeater's Avatar
Jeremy 2004 RX-8
Exclamation **My 1st somewhat major problem!**<--Transmission
Today i took my car in to Mazda because I have been having a problem with shifting from 1st to second when I red line 1st . When ever I do this, shifting into 2nd gear has been grinding every time if I am above 7k RPM in 1st. So, after finding this out (Note: I have had my car for three weeks now) I knew I needed to take it in. Turns out that the sincro is messed up from 1st to 2nd. There is a small round gear housing that go's over the larger gear to engage 2nd. They are still not sure why its not grabbing but grinding instead. They did say that it is covered under warranty and it was NOT caused by the driver. It is either a bad part, or it happened during manufacturing process. They are going to order parts in, have my car for about 3-4 nights, replace the a few parts and all the bearings. She should be roaring afterwards.
Minor annoyance. The heater **** (manual) is defective. Have to fittle with the **** to get heat/cool. Also covered and will be fixed. YAY!
Old Apr 26, 2006 | 11:23 PM
DOMINION's Avatar
I don't buy Kool-Aid
Yeah I have seen this befor. Dont know if it was you that said this on here but I cant remember what happen to the other guy with this prob. Let us know what happens.
Old Apr 27, 2006 | 12:09 AM
jryeater's Avatar
Jeremy 2004 RX-8
Shall do. i should know by mid next week.
Old Apr 27, 2006 | 08:33 AM
Aseras's Avatar
Originally Posted by jryeater
Today i took my car in to Mazda because I have been having a problem with shifting from 1st to second when I red line 1st . When ever I do this, shifting into 2nd gear has been grinding every time if I am above 7k RPM in 1st. So, after finding this out (Note: I have had my car for three weeks now) I knew I needed to take it in. Turns out that the sinco is messed up from 1st to 2nd. There is a small round gear housing that go's over the larger gear to engage 2nd. They are still not sure why its not grabbing but grinding instead. They did say that it is covered under warranty and it was NOT caused by the driver. It is either a bad part, or it happened during manufacturing process. They are going to order parts in, have my car for about 3-4 nights, replace the a few parts and all the bearings. She should be roaring afterwards.
I have both of those problems on my car too....
Old Apr 27, 2006 | 08:39 AM
Coop '04's Avatar
DELIVERED 07-17-2004
the part is a Synchro
as in Synchronizer
Just so anyone in the future doesn't think you are saying cinco, which is 5 in spanish.
Old May 3, 2006 | 08:37 PM
jryeater's Avatar
Jeremy 2004 RX-8
Exclamation
Well, my car is now at the dealer getting repaired. I will let you know how is all go's!
Meanwhile take a look at this: New Engine Flash?
https://www.rx8club.com/rx-8-discussion-3/new-computer-flash-88876/
Old May 8, 2006 | 08:46 PM
jryeater's Avatar
Jeremy 2004 RX-8
Exclamation
YAY! Got my car back! It was in the shop for 1 week and a day. My trani is fixed. They replaced all the bearings, 1st and 2nd and the sincro. Shifts like brand new!
Old May 9, 2006 | 12:59 PM
04blackout's Avatar
I have mine in the shop currently with a bearing noise while the clutch is out and trans is in neutral. When I depress the clutch (I tell it that it has no chance with Denise Richards) the noise sounds like it winds down and goes away. I just heard from the dealership that this is usual for the Ocho's, anyone else have this issue or is this the same issue as above. It doesn't pop out of gear or anything, just makes the noise while sitting still.
Old May 9, 2006 | 01:27 PM
Feras's Avatar
the Doctor
they overhauled my transmission under warranty. All better now.
Old May 9, 2006 | 02:50 PM
Romancer's Avatar
Wow, I have the same issue. When I am above 7k rpm SOMETIMES, the engine revs 9+ due to a finicky syncro. I guess I should have Mazda check mine out as well.
Old May 9, 2006 | 02:53 PM
macnrx8's Avatar
Mac in RX8
Also they should have put in and "updated" shift fork.
Old May 9, 2006 | 03:08 PM
Socr8tes's Avatar
Perfectly normal. There are a bunch of threads about this...
Old May 9, 2006 | 04:13 PM
04blackout's Avatar
Cool thanks Socr8tes
Old May 9, 2006 | 04:18 PM
let me try to shift up a few times above 7K RPM @ 1st gear right now ... be back in 2 hours.
(just to see if it applies to me too)
Old May 9, 2006 | 04:21 PM
Low Fly'n 8's Avatar
Today i took my car in to Mazda because I have been having a problem with shifting from 1st to second when I red line 1st . When ever I do this, shifting into 2nd gear has been grinding every time if I am above 7k RPM in 1st.(Note: I have had my car for three weeks now)
Is this a new car or used? If it is new you really don't want to be buzzing around the redline until it's broken in properly.
Old May 10, 2006 | 08:08 PM
jryeater's Avatar
Jeremy 2004 RX-8
Exclamation
It was used, this is my 3rd used car, and i have had 7 cars already. Thanks!
Old May 10, 2006 | 08:12 PM
Lace&MyPearl's Avatar
L' Dove
New owner...need to learn
Everyone is talking about redlining the car, is this what you need to do? My car gets sluggish and they tell me at Mazda I need to run it harder.
Old May 10, 2006 | 08:58 PM
yiksing's Avatar
the giant tastetickles
There's generally two views on break-in procedure, run it hard or run it soft, do whichever you believed in. Redlining the car once a day is a good way to get rid of carbon buildup in the car, just make sure your car is warmed up properly prior.
Feffman
SE RX-8 Forum
Oct 7, 2015 06:58 AM
Chapsy
Sep 22, 2015 09:57 AM
Vedivan1
Sep 18, 2015 12:39 PM
