Dealership Botched Airbag Replacement
Old Apr 24, 2006 | 06:05 PM
Go48's Avatar
Well CBD, time to get MNAO on your side methinks.
Old Apr 24, 2006 | 07:24 PM
snap-on's Avatar
So the Dealer is a full fledged body shop also?
I'm sure with 10k in damage the list of parts is huge. Did they install all the bags or just one? If they replaced the drivers module,did they replace the pre-tensioner also? If they replaced the main SAS module they would have had the inhale it with a PMI.
IMHO they should at least give you the code. It appears they are going for a supplemental claim with USAA.
Old Apr 25, 2006 | 05:24 AM
Gomez's Avatar
Shifty Bastard.
Originally Posted by Cool-Blue-Dad
Here's my question for the forum - do you know the meaning of the airbag light flashing twice, pausing, then flashing three times? I know some members had problems with loose harnesses - is this like that?
The service manager mentioned the passenger airbag (could only be that or the driver's), but no details.....
Hi mate, good luck with this.
This is a passenger seat airbag problem. Code B1996,7,8 or 9.
B1996 is a airbag short cct to power supply fault.....B1997 is a airbag short cct to ground fault.......B1998 is an airbag cct high resistance fault (this one is the most likely, IMO)......B1999 is an airbag cct low resistance fault.
I'm going for B1998 because this one often shows up if the connector under the seat is not fully home. The kids in the back seat kick it occasionally. Check here first.
Cheers,
Gomez.
Old Apr 25, 2006 | 08:43 AM
saturn's Avatar
i pwn therefore i am
Why are you traveling 130 miles to get to the dealer? Are there no other dealers around?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
thegoodfella334
Sep 2, 2015 09:57 AM
dancingdan42
Aug 19, 2015 09:29 AM
mesaboogie
Aug 7, 2015 10:48 AM
dbarber
Jul 25, 2015 01:34 PM
