under hard acceleration trouble shifting into forth gear
Old Apr 21, 2006 | 06:31 PM
northerner's Avatar
I redlined it in third gear and it wouldn't go into fourth, then I got a cel and couldn't go higher than 6000 rpm until the cel went away. Tried it again and still put it into forth. But when I shift at lower rpm's there are no problems. Has this happen to anyone else?
Old Apr 21, 2006 | 06:39 PM
northerner's Avatar
Sorry I spelled the word fourth wrong
Old Apr 21, 2006 | 08:10 PM
Unser's Avatar
My tranny went south too, at speeds greater than 65 there was a grinding noise and feel going from 6 to 5, all other gears were fine.
Well, they opened up the transmission and called Mazda tech.serv. They are rebuilding it now and said the 5th gear was messed up, and the synchronizer on it. I don't think any gear other than the 1st and 2nd had synchronizers !!
well, I get the car back after the weekend, hope they can balance everything back to the way it was.......
Old Apr 22, 2006 | 03:41 AM
how full was your gas tank.. if it was less than 1/3 full you might have had fuel starvation and a missfire... then the ecu goes into the limp mode...
dont ask me how i know..
Old Apr 22, 2006 | 06:56 AM
northerner's Avatar
My gas tank was full.
Old Apr 22, 2006 | 11:05 AM
LostAngel's Avatar
By any chance was your engine cold when you did this? The rotary will run in limp mode if you try going hard on the engine when it's not fully warmed up.
Old Apr 22, 2006 | 05:44 PM
northerner's Avatar
No, my engine was warmed up. I think it went in limp mode when I couldn't put it in fourth and it revved at 9500 or over.
Old Apr 22, 2006 | 06:29 PM
LostAngel's Avatar
that might be it!
Old Apr 23, 2006 | 07:14 AM
northerner's Avatar
I'm not worried about the engine going in limp mode, just worried about not being able to put it in fourth gear.
Old Apr 23, 2006 | 09:15 AM
NVMYGT's Avatar
IM2BZ2P
That happened to me a couple times back. My car was not cold at all. I noticed that it was only around 7500k+. I havent tried it again recently, but usually shifting at anyting lower is no problem.
Old Apr 23, 2006 | 12:28 PM
dastallion951's Avatar
did u fully depress ur clutch in?? ive had that problem too.......before shiftin from 3 to 4 sometimes grinds a bit.......but if u fully depress the clutch, shift a bit slower, if ur synchro is the thing thats fucked up shift a bit slower on the 3-4 shift..... n it should work for now.
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
DVerdeyen
Sep 13, 2015 11:19 AM
ed0128
Sep 9, 2015 04:50 PM
