Anything that will upgrade the Shinka Suspension?
Old Apr 20, 2006 | 02:22 AM
uncivilracer's Avatar
Turbo Racer
I am looking to upgrade anything on the suspension before I go more power on the car. Is there anything that will upgrade on the Suspension to make it any better? Thanks in advance.
Old Apr 22, 2006 | 12:02 AM
rickeo's Avatar
running on double cream!
look into a set of coilovers.
Old Apr 22, 2006 | 03:36 AM
Fanman's Avatar
Still get the MS setup. As I understand it the Shinka still uses the standard RX8 suspension but just with urethane foam injected cross member. You can still add MS Springs, Shocks, Sway Bars, Strut/Shock tower bars, etc.
Old Apr 22, 2006 | 03:45 PM
Turbo Racer
So the "upgraded" shinka suspension is only a urethane foam cross member?
Ok that is about what i needed to know. More or less everything can be upgraded for the most part. What is the top of the line coil-overs?
Got me the MazdaSpeed Strut Bars coming! Guess I need to look into Sways and Coil-Overs.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
duworm
Oct 1, 2015 04:57 PM
Quiggs321
Sep 30, 2015 05:34 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
