Throttle Loss Cel Came On
Old Apr 19, 2006 | 11:22 AM
snkpkp's Avatar
,I was doing about 90mph in 4th when the cel came on with a small SPUT noise from exhaust sounded more like a miss fire in the plug and the throttle came to 3000 and When ever i tried pressing, the response started to shut me off. I pulled over, called a friend who has an RX8 , he came over and disconnected my battery for 3 mins and re connected it, and the throttle problem was gone along with the CEL light and car runs just fine. I am just confused what should i do now. I drove about 2 hours after that with high rpm and at very very high speeds and no problem seems to be found. Any ideas guys what might have happened? I think I did sort of went to 9500rom while shifting from 3rd to 4th....
Old Apr 19, 2006 | 11:26 AM
zoom44's Avatar
knock
Old Apr 19, 2006 | 11:29 AM
snkpkp's Avatar
huh?
Old Apr 19, 2006 | 11:51 AM
BlueEyes's Avatar
Knock. When the AF mixture in not ignited smoothly. Usually the pressure and temperature in the combustion chamber spontaneously ignites unburned portions of the AF mixture before the flame front progresses to that area. It causes a reverberant shockwave in the combustion chamber which makes a pinging, or knocking sound. The 8 has a knock sensor and will retard engine performance to prevent it.
Old Apr 19, 2006 | 12:02 PM
snkpkp's Avatar
phew!!! Thanks guys. Do you think I should still take it in for error code or its not needed?
Old Apr 19, 2006 | 03:07 PM
Go48's Avatar
I would have it checked out in case it's something more serious. Anyway, you would want to get it on the record in any case. Too bad your friend cleared the CEL. You will have to let them know that.
Old Apr 19, 2006 | 03:12 PM
snkpkp's Avatar
that wont be a problem, cause i will take it to a workshop which services mazdas but ita not an official one because we dont even have a mazda delearship in Bangladesh. They do have all the computers and scanalyzer etc. But I have to pay for everything which sucks even though i bought mine new (JDM version).
Old Apr 19, 2006 | 03:15 PM
snkpkp's Avatar
my question is If knock happens again say for bad gas quality how long will be the car in retard mode if not reset by ecu? do you guys know the procedure?
Old Apr 19, 2006 | 03:24 PM
Wurmfist's Avatar
FEAST!
engine retard? Is that the LIMP mode these cars can go into. I think the only way to get out of it is to disconnect the battery and clear the memory or do that pushing the break pettle and holding your lips right thingy.
Old Apr 19, 2006 | 03:32 PM
snkpkp's Avatar
wurmfist or can anyone talk in more detail what wurmfist suggested about brake paddle and lips...i am a bit confused.
Old Apr 19, 2006 | 04:51 PM
Go48's Avatar
Guess I didn't state that clearly enough. My point was that had your friend not cleared the CEL the mechanics could read the code to help with diagnosing the problem.
Old Apr 19, 2006 | 05:18 PM
snkpkp's Avatar
ohhh man....but then again i was not getting no throttle response at all in a very shady part of the highway...getting started and leaving was the prime objective at that moment.....
Old Apr 20, 2006 | 05:51 PM
zoom44's Avatar
sound sliek it might be a bad tank of gas after reading what happened to your wife. what octane fuel do you have in it now?
Old Apr 27, 2006 | 05:34 PM
snkpkp's Avatar
its supposed to be 91 but who knows, its Bangladesh...to my idea there is probably **** in the fuel.....!!!i I add octane boosters. Car ran fine until two weeks ago . Got the car in Sep 2003 brand new. has now 18749 miles. Just did a road trip for over 600 miles. CEL didn come on but i never reved that much , my 1 1/2 year old angel was in the car along with my real life speed limiter = wife. I am just so scared of pushing the car to its limits now....everytime i rev now i feel the CEL is gonna come on and I will be retard mode. Well there is only one way to find out....
Old Apr 29, 2006 | 11:34 AM
snkpkp's Avatar
cel again with limp mode after cousin stalled car three times......Help...is this common after someone stalls it?
Old Apr 29, 2006 | 11:11 PM
snap-on's Avatar
Does the CEL flash? You may have fouled the plugs.
This is a HP model...correct?
Old Apr 30, 2006 | 06:37 AM
snkpkp's Avatar
nope not flashing cel. tested few times, if you stall twice the car will go to limp mode. if you reset its fine. first time limp mode because of missfire, found a pebble inside exhaust system.
Old Apr 30, 2006 | 11:40 AM
snap-on's Avatar
Ahh
The old "double stall/pebble in the tail pipe" code.
IIRC the PCM will set a P0WTF.
You really need to give us more to work with. Even if you can't get to a Mazda dealer you can get the code pulled at any Ford dealer with a WDS.
Old Apr 30, 2006 | 03:15 PM
snkpkp's Avatar
P2106 thats what the computer says ..a friend of mine has the scanalyzer and found this, i was not at home he came and did it while i was away and left a note saying that was the Code, and now i cant get him on the phone god knows where he is, can anyone say what this is, this CEL happens only when vehicle stalled twice. Anyone?? help. I dont know why my friend didn explain what it was.
Old Apr 30, 2006 | 03:48 PM
Go48's Avatar
Maybe because "Throttle actuator control system-forced limited power" wouldn't have meant anything to you? See the information below from the service manual. Read left to right.
Attached Thumbnails Throttle Loss Cel Came On-2106_1.jpg   Throttle Loss Cel Came On-2106_2.jpg   Throttle Loss Cel Came On-2106_3.jpg   Throttle Loss Cel Came On-2106_4.jpg   Throttle Loss Cel Came On-2106_5.jpg
Old Apr 30, 2006 | 04:04 PM
snkpkp's Avatar
THANKS. will read through now. thank you very much.
Old Apr 30, 2006 | 04:09 PM
Go48's Avatar
Sure. Good luck finding the source of the problem.
Old Apr 30, 2006 | 05:04 PM
snap-on's Avatar
Thanks Go48,
Amazing how much easier it is once a code is posted.
I'm still looking for the relationship between the TB code and the mis-fire.
Old Apr 30, 2006 | 05:10 PM
snkpkp's Avatar
unfortunately when cel came after missfire the ecu was reset and no log found on that error. that was also the first time ever my car showed the cel in 2+years and 18000miles/29000km
Old Apr 30, 2006 | 05:18 PM
snap-on's Avatar
Good luck with the throttle body diag.
