torque on rear shock nut...
Old Apr 18, 2006 | 07:36 PM
brattesani's Avatar
broken swaybar king
does anyone know how to torque this without putting stress on the adjuster? thanks
Old Apr 18, 2006 | 08:43 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
You need an air tool!!! With a deep socket. That was the only way that I got my JICs on. Confirmed from a JIC dealer. The piston shaft just spins with hand tools. With the impact wrench, the fluid inside the shock (strut, sorry) will give enough resistance to tighten the nut.
Looks like you have Konis? I would check with a dealer that sells them first. But this is likely the only way.
Old Apr 18, 2006 | 08:52 PM
TeamRX8 said that Koni forbids the use of air tools to install that nut But that's what I do as well.
It is difficult to find a way to hang on to the shaft to keep it from spinning the way the shock mount upper is designed
Old Apr 18, 2006 | 09:01 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Difficult? That is understated. I spent a whole day thinking about it and couldn't even come up with an idea to try.
Old Apr 19, 2006 | 08:00 AM
apotocki's Avatar
I agree with TeamRX8 - I just installed Koni's and there are instructions to NOT use air tools. I used a combination wrench and held the shaft with an ALLEN wrench as my Koni's had this.......
I know from installing the OE stuff, there was no ALLEN capability and I was able to tighten it without the shaft turning (not sure how/why but I was).
A suggestion may be to wrap the shaft (sounds kinda wrong) with something like a cloth and hold onto it with a pair of channel locks/vise grips?
Old Apr 19, 2006 | 08:04 AM
CRX Millennium's Avatar
AA = Autox Anonymous
See my post here for the same issue: https://www.rx8club.com/1328278-post/
There was no way for me to torque it since I decided to do everything bolted to the car,
instead of taking the assembly out. In any case, with using the 5mm Allen hex key
in the top nut void, and turning it with close-box wrench, the nut eventually stopped
moving no matter how much I tried. Seems to be quiet & noise-free so far (knock on
wood).
Old Apr 22, 2006 | 07:59 PM
velocityredRX-8's Avatar
Im having a similar problem but instead i cant take off the nut without the shaft turning. I currently have tein coilovers but now I am going back to stock suspension and need to put the upper mounts on my stock shocks. With tein basics you can use a crescent wrench to torque down the nut and keep the shaft from moving since its not damper adjustable. Now that I want to disassemble the coilovers but once the nut reaches a certain point, I cant use a crescent wrench anymore. The shaft just moves with the nut. can anyone help?
Old Apr 22, 2006 | 09:22 PM
Winning 8's Avatar
Hot Pit
use Flare Nut or Torque Adaptor.
Attached Thumbnails torque on rear shock nut...-47990.jpg   torque on rear shock nut...-47138.jpg
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Paul_Y
Sep 21, 2015 02:23 PM
