Racer X-8
08-12-2003, 10:12 PM
A friend at work informed me that my tires were installed wrong, and because of that, I had a whole lot of counterweights added to my rims to account for it.
He said that, on the sidewalls of the tires, the red dots on the right and the blue dots on the left should be oriented opposite the valve stems.
I think he said that the dots mark the heavy point of the tire. To minimize required counterweights, the heavy side of the tire should be opposite the valve stem because the valve stem creates the heavy side of the wheel. So, the two heavy sides should be opposite each other to minimize the out-of-balance condition that is then corrected by adding counterweights. Any unneccessary counterweights make the whole assembly heavier, more polar moment of inertia to have to spin, reducing power output efficiency a little.
My red/blue dots are oriented at the valve stems & my counterweights look to be a lot, like about 4" in length.
I wonder if the pressure sensors have anything to do with this?
