Greddy Turbo Problems HELP!!
Old Apr 14, 2006 | 02:36 PM
VarneyMazda's Avatar
Northeast Pimpin'
OK here it goes,
I started Last week having the shop install my greddy turbo kit, oil pan, ProFec e01, Turbo XS BOV
The problem i am having is that i am running Severd P2's @ 490cc and running map 15 that was provided to me by MadDog.
After the kit was all installed i started it up and the idle will be very rough, and then eventually stall
Is there anything somebody could do to help me get this thing running
Thanks guys
Old Apr 14, 2006 | 03:13 PM
two rotors's Avatar
Sounds like you might have an intake leak somewhere.What set up do you have for air filter?What does it run like at other than idle?
Old Apr 14, 2006 | 03:21 PM
WantedTwo's Avatar
C4 burns real good
hope you didn't ingest anything....
Old Apr 14, 2006 | 03:32 PM
Northeast Pimpin'
im running the stock greddy kit, i de-severed the injectors and unplugged the rpm adapter per greddy and it still has a horrible idle
Old Apr 14, 2006 | 03:38 PM
BigOLundh's Avatar
#1 Legend
can you get your hands on an Wideband Air Fuel Monitor?
Even though your using MadDogs map... your in a different car, and that map wasn' tuned specifically for you. Its possible your running too lean in idle, and thats what the A/F might tell you.
Also, double check all the pipeing to make sure they are secure.
Old Apr 14, 2006 | 03:40 PM
Moostafa29's Avatar
Storm Trooper
How does the engine sound? Check for leaks, if you can't see/hear anything, perhaps do a compression test.
Old Apr 14, 2006 | 04:10 PM
OfficerFarva's Avatar
I have something kind of like that going on. My idle is 100% smooth though, unless i turn on the a/c. It has trouble starting occasionally, and i j ust replaced all the spark plugs. Anywhoo, it's probably just a bad starter since my engine has been flooded 3 times before it was rebuilt. I think to be honest that my prob is it is idleing too rich sumtimes. It should stay around 14 to 16 but my wideband gauge often displays it dropping at idle to 12 and sumtimes into the 11 range. So, i feel like it is idleing to rich and maybe thats what could be giving u problems too? Just a thought.
Old Apr 14, 2006 | 04:11 PM
two rotors's Avatar
If you are running a Mad Dog Severed map,then the idle is controlled only by the original Mazda mapping in the ecu full stop.So any idle problem is due to your intake set up--something must be leaking---joints,BOV or something,are the vacuum hoses properly connected?
Old Apr 14, 2006 | 08:06 PM
MadDog's Avatar
Consiglieri
Yeah, the eManage is only active under boost. If your problems are at idle, then its not the tune. An the PCM isn't expecting to use the P2's until the high RPM. Tighten the BOV all the way just to make sure that it isn't leaking and causing this issue. You can then back-off of it. Also check that the MAF wasn't damaged in the install.
Plan B: verify the position of the 490cc injectors. Make sure they aren't installed in the P1 position.
My money is on the BOV.
MD
Old Apr 14, 2006 | 08:28 PM
WantedTwo's Avatar
C4 burns real good
how bad of an idle are we talking about cause when I popped a seal my idle was butt and the exhaust smelled very very rich. It also tossed codes like crazy so that may be a hint. Hope its nothing too bad.
Old Apr 14, 2006 | 08:42 PM
Northeast Pimpin'
Thanks for all the help guys I will definately check the bov tommrow to make sure its connected
As for the idle it won't even stay running for more than a second and if you feather the throttle it will stay running the exhaust smells oily but it may just be all the oils burning off the new parts
When I was talking to the mechanic he thinks there sounded like a loose vacum near the intake manifold
Any quick ways to tell if you blew an apex seal?
I don't think that's even a possibilty though because the car has NEVER stayed idling for more than 5 seconds
Old Apr 14, 2006 | 08:52 PM
Rotary78's Avatar
ZOOM ZOOM ZOOM
if what maddog said doesn't work, then I would go back and make sure everything is in the right place, and that everything is installed correctly. Is there a CEL on? I wish I could help you, but I'm just starting to understand the components of the Turbo...
Old Apr 15, 2006 | 02:16 PM
Northeast Pimpin'
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Randolph Alvarez
May 30, 2016 01:08 AM
ed0128
Sep 9, 2015 04:50 PM
