Would I be able to use LE37T 19"x9.5 +22 at the rear?
Old Apr 9, 2006 | 10:24 PM
charlex's Avatar
Thanks for advising.
Old Apr 9, 2006 | 10:31 PM
Im_DANomite's Avatar
I love GOOOLD
no
Old Apr 9, 2006 | 10:48 PM
NgoRX8's Avatar
that is guna stick out big!
Old Apr 9, 2006 | 10:57 PM
Howdy1606's Avatar
Howdy
nope wont work
Old Apr 9, 2006 | 10:59 PM
FABRO's Avatar
Registered Ricer
Having a 22' on the rear would be a bad idea. check out the sticky about having a staggerd setup since it sounds like you want to go that route. If I were you I would just get the 19x9 for front and back.
Old Apr 10, 2006 | 01:16 AM
9.5 and even 10.0 will fit all around, just not with that offset
Old Apr 10, 2006 | 01:34 AM
lazi's Avatar
drivelinestore.com
yup the offset is too low for our car's we have "high" offsets
Old Apr 10, 2006 | 11:25 PM
IZoomZoomI's Avatar
Boost needed
19x9.5 would fit in the front?
Old Apr 10, 2006 | 11:40 PM
19x9.5 will fit in the front but probabyly only with a +30 or +34. You could do a +22 in the front but expect your tread to wear out within a few months.
Old Apr 10, 2006 | 11:43 PM
IZoomZoomI's Avatar
Boost needed
what would be ideal for 19x9 all around would +37 work for front and back?
Old Apr 11, 2006 | 12:36 AM
It will fit in the general sense, but I would not recommend it unless you are going to modify the liner and fender lip. I have 9.5 @ 45mm offset and while it clears well when the wheels are pointing straight ahead the tire would be heavily into the fender lip when the suspension is seriously lowered/compressed and the wheel is turned substantially
Here is a pic of my 18 x 9.5 @ 45 with 265/35-18 Yokohama Advan Neova tire at full compression. When the wheel is at a tyical lowered ride height; approx. 26 " from the ground to the fender lip, the tires is about even with the fender lip. I have about 30mm more upward travel clearance than the OE and typical aftermarket shocks, but it will give you the idea. The SLA suspension has a lot of camber gain that pulls the top of the tire inboard as shown, but at this position I can't turn the wheel more than 15 deg before it slams into the lip. It would take some pretty stiff springs to keep it from rolling over and causing this. I'm installing 500# springs up front, but this would ride very rough for most people on the street.
Old Apr 11, 2006 | 12:57 AM
lazi's Avatar
drivelinestore.com
i love the neovas *drools*
Old Apr 11, 2006 | 02:05 AM
have you seen the new Bridgestone RE-01R tire?
http://www.tirerack.com/tires/tires....Potenza+RE-01R
Old Apr 11, 2006 | 04:40 AM
RX4life's Avatar
yes it will fit.. but you need to roll the fenders..
i have a 25 offset.. my proof..
Attached Thumbnails Would I be able to use LE37T 19"x9.5 +22 at the rear?-img_0549.jpg   Would I be able to use LE37T 19"x9.5 +22 at the rear?-img_0548.jpg   Would I be able to use LE37T 19"x9.5 +22 at the rear?-img_0550.jpg
Old Apr 11, 2006 | 09:35 AM
anything will fit if you're going to modify the fenders and run narrow tires for the width, but your front wheels will hit the fender lip still with enough compression while turned
Old Apr 12, 2006 | 01:31 AM
rx4life..are those 245's in that pic?
Old Apr 12, 2006 | 03:38 AM
RX4life's Avatar
^^^yes...245/35
Old Apr 12, 2006 | 03:41 AM
RX4life's Avatar
just run a higher offset in the fronts
Old Apr 12, 2006 | 05:58 AM
that's what I've been saying ...
tjohnmeyer
Sep 28, 2017 05:03 PM
duworm
Oct 1, 2015 04:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
