TPS and speedometer wire locations
Old Apr 9, 2006 | 09:19 PM
rkostolni's Avatar
I know tps and speedo wire locations have been asked for before, I found them so thought I'd make a post.
I located a tps wire that gives absolute throttle position measured at the throttle plate. It is located at the factory ecu in the first plug location 1J. It provides 0.4-0.8v with 0% throttle, 3.8-4v at 100% throttle, and with all the values inbetween. The attached pic shows the tps wire location in the harness.
The speedometer wire is a green w/ red located in the radio harness
Old Jan 17, 2014 | 08:58 AM
Banshee8's Avatar
VA
On the topic of instrument cluster wiring, where can I find a wiring diagram for the whole instrument cluster? I'm looking into splicing a switch into the ABS/DCS warning light wires. I don't know if the cluster is entirely digital however - or if it's partly analog: which wires illuminate which warning lights.
Old Jan 17, 2014 | 12:06 PM
logalinipoo's Avatar
Driving my unreliable rx8
The speedo has to come off of the transmission control box(or something like that) I have yet to find that box. It does not come out of the factory ECU. Not that I could figure out.
Old Jan 17, 2014 | 03:11 PM
CRO8TIA's Avatar
Im sure I have read somewhere in here, the speedo wire is connected to the ABS, though I could be mistaken .
Old Jan 18, 2014 | 01:25 AM
No, the speed is read from the ABS, and ABS got it from the wheels sensors.
Thats why if ABS goes bad, u will not get the speed at all
and when u have Mazda's IDS, you can use it's monitor pid to read each sensor's speed.
RevMeHarder
Jun 1, 2026 02:30 PM
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
DVerdeyen
Sep 13, 2015 11:19 AM
