CEL after oil change
Old Apr 2, 2006 | 12:04 AM
rommel's Avatar
so the 2nd time I start my car after an oil change to a full synth my check engine light has gone on... anyone else experience this? Is it just a matter of the ECU adjusting to the new type? Car feels perfectly normal.
Old Apr 2, 2006 | 12:30 AM
Captain Amazing's Avatar
Did you fill up on gas yesterday?
Old Apr 2, 2006 | 01:09 AM
yea,
what he said...
unless you left the oil filter off... changing the oil to olive oil would not through a cel....
ok well after a while after the mop pumps the olive oil into the engine and the plugs foul, it might.
but if you you used oil made for a car... you got other issuses.
Old Apr 2, 2006 | 03:03 AM
rommel's Avatar
yah I did fillup with gas yesterday... what would that have to do with it?... I checked to oil filter and everything seemed kosher there.
Old Apr 2, 2006 | 03:06 AM
check to see gas cap is tight.
have dealer check cel #
bad gas caps are a known issue..
Old Apr 2, 2006 | 03:47 AM
rommel's Avatar
K the gas cap wasn't on really at all... I was able to just pull it off... I put it on and drove it awhile but the light still was on... will it go off by its self or will I have to have the dealer reset it?
Old Apr 2, 2006 | 03:51 AM
a couple of drive cycles will reset it... i think is is like 20 or so...
if that is it you are good...
Old Apr 2, 2006 | 04:19 AM
rommel's Avatar
excuse the newbish question... but what exactly do you mean by drive cycles?
Old Apr 2, 2006 | 04:43 AM
Raptor2k's Avatar
Club Marbles Member
Rommel, what year is your 8? Have you had the latest flash?
Taking it to the dealer will solve the problem under warranty anyway, it might be a leak in the gas pipes, which is common to the '04 rx8s. I had it, even though I didn't notice anything while driving except the CEL.
Old Apr 2, 2006 | 04:50 AM
rommel's Avatar
I have an 04... I just bought it 3 weeks ago... but I went to the Mazda Dealership last week to make sure its up to date on all the recalls... they said there were no outstanding recalls... anything else I should be looking for?
Old Apr 2, 2006 | 06:46 AM
Go48's Avatar
Start the car, drive it, shut it off. That's a drive cycle. Don't fret, if the loose gas cap was the problem the CEL will self-cancel eventually.
Old Apr 2, 2006 | 09:00 PM
rommel,
relax. dont believe all the sky is falling threads. it will be fine.
Old Apr 3, 2006 | 12:32 AM
It takes 40 cycles (engine on then off) for the CEL to go away.
Old Apr 3, 2006 | 12:33 AM
Make sure you give your gas cap 4 clicks so you know it is tight. A loose gas cap will cause the CEL.
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
talonhart2
Aug 26, 2015 04:14 PM
RotaryRider
Jul 20, 2015 07:05 AM
