Starting problems
Old Mar 22, 2006 | 04:16 PM
Petrus's Avatar
v e i l o c i t y
Keyless locking and alarm
Ok, I´ll try to make this as short as possible...
Last autumn I had GReddy turbokit installed... I have driven the car since an it works fine. Since december I had it in my garage with the battery disconnected and a lot of things removed. Now I have added 5 aftermarket gauges, a turbotimer, boostcontroller, wbo2 sensor, lightweight pulleys, hi flow cat.
NOW, when reconnecting the battery to start my car it wont start. I get ignition and the starter works.... but it doesn´t fire. Kinda like a very bad battery, but I tried with starting cables as well...no luck.
AND when shutting all doors and try to lock the car (and turn on the alarm) neither works. Only the passenger side door locks.
Anyone got any clue on whats wrong?
Old Mar 22, 2006 | 04:38 PM
low battery volt. charge battery. jumping it will not be enough.
Old Mar 23, 2006 | 04:06 PM
Nubo's Avatar
Lubricious
Sounds like your battery is weak, and then you flooded. Once you charge your battery be prepared to un-flood the car.
Old Apr 20, 2006 | 04:41 PM
Petrus's Avatar
v e i l o c i t y
Originally Posted by Petrus
...when shutting all doors and try to lock the car (and turn on the alarm) neither works. Only the passenger side door locks.
Yeah, I still got this problem... Help please.
Old Apr 20, 2006 | 05:01 PM
zoom44's Avatar
check all the fuses?
Old Apr 21, 2006 | 06:05 PM
Petrus's Avatar
v e i l o c i t y
You´re saying there´s one fuse for each door? Boot and driversside door works fine.. it´s just the passenger door I have issues with
Old Apr 21, 2006 | 11:39 PM
Blue87Sport's Avatar
Rotary only since 1980
Try cleaning your battery terminals and clamps. Maybe some corrosion or oxidation built up on them over the winter that is causing excessive resistant and lower the voltage to the starter. And make sure the clamps are on tight.
Old Apr 22, 2006 | 05:58 AM
Go48's Avatar
Did you fully charge the battery as suggested by others? If not, fully charge the battery, make sure your trunk and hood are completely closed. Then try the remote.
Old Apr 23, 2006 | 02:35 PM
Petrus's Avatar
v e i l o c i t y
I drive my car daily and have driven many many miles, so the battery is most definately charged.
xAgyex
Jun 3, 2026 03:47 PM
Jaco Greyling
Jan 6, 2019 08:39 AM
uZu
Dec 30, 2015 12:35 PM
Tyblat
9
Aug 6, 2015 10:43 AM
robd1337
Jul 31, 2015 09:35 PM
