help with scanalyser
Old Mar 22, 2006 | 03:10 AM
bedrock83's Avatar
!!Speed Racer!! VrOoM
I recently installed scanalyser program and can't get my computer to connect to my car via the cable. My computer uses the 15 pin connection, so I had to use an adapter. It says access denied sometimes, and other times will try to connect but will not. Im using a dell computer, with windows xp. Can someone help?
Old Mar 22, 2006 | 03:27 AM
yiksing's Avatar
the giant tastetickles
Drivers? Port Settings?
Old Mar 22, 2006 | 03:29 AM
bedrock83's Avatar
dont know much about that, would you care to enlighten me?
Old Mar 22, 2006 | 03:41 AM
yiksing's Avatar
Don't know whether this would help but I got it off the webpage
Hymee Info
Important information If using a SERIAL to USB adaptor: After installing drivers for the unit...enter the 'system' in the control panel. From their open up the 'device manager' located in the hardware tab. Located the SERIAL to USB driver in 'ports.' Click on properties in driver settings and change the 'flow control' drop down menu to the 'hardware' setting instead of 'automatic' or 'xon xoff'. Now everything should work great!
Old Mar 22, 2006 | 03:44 AM
bedrock83's Avatar
Yea i saw that too, but I tried it, and I dont have the options that it stated. Thanks though. There are like 8 or 9 ports, I dont even know which is which. Do you know any way to find out?
Old Mar 22, 2006 | 03:50 AM
yiksing's Avatar
Its probably a serial COM1 or COM2 port but I'm a dunce in these stuff so not much help I am. Try going to Control Panel -->System-->Click Hardware Tab-->Device Manager. Under Ports, there's COM1. Doubleclick on that then go to Port Settings.
Old Mar 22, 2006 | 03:53 AM
bedrock83's Avatar
theres no com1 i looked for it, only com6, and 8. How do i change it, or add it?
Old Mar 22, 2006 | 04:07 AM
yiksing's Avatar
It shouldn't matter since your computer will just assign a different number for each port. Have your laptop plug onto your car (your car should be in a status where the ECU can be read, maybe ignition on or something), reboot your laptop then go to the device manager and then right click on your laptop's name and scan for hardware changes. If no new ports are detected then chances are COM8 or 6 is one of them then you can change the port settings to the one posted earlier.
It sounds like the laptop wasn't able to detect your car, that's why I suggest try rebooting it.
Old Mar 22, 2006 | 04:27 AM
Gomez's Avatar
Shifty Bastard.
Hang on.....I'll get the subject matter expert onto this .
Standby......
Old Mar 22, 2006 | 04:46 AM
sco's Avatar
sco
Thanks Gomez
I replied to your email, but just in case this is quicker..
Usually access denied means that some other software is trying to use the port at the same time. Do you have something like palm pilot sync software or Microsoft ActiveSync installed. If so, can you disable the serial port in that software or uninstall it?
If not, and you're not sure what could be using the port already I can try and work it out... to do this you need to do the following:
1. Open up task manager (right click start bar, select Task Manager)
2. Change to processes tab
3. Make sure "Show processes from all users" is ticked
4. Expand the window so it shows the full list
5. Do a screen shot and send to me.
To do a screen shot usually as simple as:
1. Press the PrtScn key
2. Create a new email
3. In the body of the email, press Ctrl+V to paste the screenshot
4. send to support@performancedesign.com.au
Cheers
sco
Old Mar 22, 2006 | 06:21 AM
expo1's Avatar
He's as bad as Can
I had a similar issue and the problem was because of dirty contacts in the ODB-II connector. Radio Shack sells an aerosol contact cleaner that worked.
Old Mar 22, 2006 | 11:47 AM
bedrock83's Avatar
Haha Id probably just try to blow in it like a super nintendo. Ill try that though. Thanks for the help guys.
Hymee
Series I Engine Tuning Forum
65
Feb 13, 2009 06:13 AM
Hymee
Europe Forum
19
Feb 12, 2009 02:38 PM
Daemos
91
Dec 24, 2008 02:44 PM
erx8s
Australia/New Zealand Forum
Jan 22, 2008 04:14 AM
