Installed new airbag light still on??
Old Mar 20, 2006 | 02:50 PM
modforce's Avatar
I installed my new airbag in the seat on A-pillar and the lights are still on, on the dash. Do I just need to have a tech use a scanner to turn the light off and that wouldthen make them active again? I know in my mustang that I had I put in a new air bag deployment box under the dash and I am not sure my RX8 has this little box. I am hoping that by turning the lights off with the scanner tool that the tech's have this will allow them to be ready for use again. Any one know this answer? Help if greatly appreciated.
Old Mar 20, 2006 | 04:39 PM
Go48's Avatar
Remove the negative cable from the battery for a few minutes to clear the PCM. If the intial problem has been resolved, the light should not return. You will have to do the DSC calibration routine after reattaching the cable. See the owners manual for the simple procedure.
Old Mar 20, 2006 | 07:24 PM
modforce's Avatar
Excuse my lack of knowledge on the RX8 but what is the DSC calibration routine? I tried the negative terminal disconnect and the light still showed back up.
Old Mar 21, 2006 | 05:39 AM
Go48's Avatar
The airbag light or the DSC light? If the airbag light is still on there apparently is an un-resolved problem with that system. You can clear the light momentarily, but it will return until the problem is resolved.
For the DSC light, like I said, calibration procedure is in the manual. But since I'm feeling particularly generous this morning, I scanned the page for you.
Attached Thumbnails Installed new airbag light still on??-dsc-calibration.jpg
Old Mar 21, 2006 | 08:00 AM
modforce's Avatar
I appreciate your generousity! I am going to check and see again..
Old Mar 22, 2006 | 01:08 AM
I believe it has to be cleared with a scanner (the airbag light)
the DSC calibration routine is a separate function, it will calibrate itself eventually, just quicker using the routine
Old Mar 22, 2006 | 07:23 AM
modforce's Avatar
Thanks as this is what I thought as well!
Audio Concepts ATL
Sep 26, 2021 01:59 PM
mesaboogie
Aug 7, 2015 10:48 AM
Stubbs
Jul 28, 2015 09:23 PM
AussieGray
Jul 16, 2015 03:58 AM
