My Cruise Control dont work
Old Mar 12, 2006 | 05:40 AM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
Unhappy My Cruise Control dont work
My Cruise Control dont work...... today i tried turning it on for the long straights on the freeway and it did not set.....It turned on to the cruise control lights.... but nothing???????
well the car just came back from transmission work....right after i installed the revi intake??? it had nothing to do with the VFAD right???
well i dont know i juss thought id ask if anyone has the same problem.....
Old Mar 12, 2006 | 10:48 AM
yiksing's Avatar
the giant tastetickles
Did you ON it and then SET?
Old Mar 24, 2006 | 04:45 PM
yea i did......at freeway speeds it doesnt work after playing with it for 10min...Ive used it before so i know it used to work...then at street speeds it works....but back on the freeway it doesnt?? dont know how that got to happen
Old Mar 24, 2006 | 05:41 PM
BRGREEN8's Avatar
uh how fast were you going ?
Old Mar 24, 2006 | 06:30 PM
Go48's Avatar
Take it back to the people who did the tranny work. They may not have reconnected a sensor.
Old Mar 25, 2006 | 12:57 AM
dillsrotary's Avatar
jersey fresh
Originally Posted by Dookie_Rx-8
My Cruise Control dont work...... .
neither does public schooling.
Old Sep 9, 2008 | 11:04 PM
rotarydrifter's Avatar
Im having this problem as well... I use cruise control everyday and just two days ago it stopped working... the cruise control light is on but i cant seem to set it...
Old Jan 31, 2009 | 06:31 PM
it ended up being the switches on the steering wheel i decided to take it in and they replaced them...no cost .
Old Dec 11, 2009 | 07:49 PM
B-Ron's Avatar
Im having this same problem after having my tranny replaced. Ive taken it back to aamco who did the tranny and they said they didnt do anything....
I talked to a mechanic friend of mine and he suggested maybe there was a speed sensor cable they didnt hook back up right when putting the tranny in. Anyone know about this?
Old Nov 5, 2010 | 03:00 PM
toddman's Avatar
RotaryFreak
I am having the same problem with my cruise control. It turns on, but will not engage. From what I have read on here, it sounds like it may be the switch itself. I guess it is time to head to the stealer...
Old Dec 1, 2010 | 08:34 AM
fastlane425's Avatar
fastlane425
my main cruise control light wont turn on at all has anybody had that happen
Old Dec 1, 2010 | 08:43 AM
Dirt_Nasty's Avatar
Filth in a world of Clean
This.
Old Apr 2, 2017 | 10:11 PM
MaddmaxxII's Avatar
Same here, I just bought my rx8 and the cruise control doesn't work at all. press the ON button and nothing at all
Old Apr 3, 2017 | 02:04 PM
Probably a problem with the button since the cruise control itself is controlled by the ECU.
Old Apr 4, 2017 | 06:21 AM
MaddmaxxII's Avatar
Thanks, I'll get it checked out
Old Apr 4, 2017 | 10:12 AM
scottish's Avatar
SHINEY 8!!
If it's a manual transmission It will be the clutch position switch on the clutch pedal or the neutral switch on the transmission.
Either one of them will prevent the cruise control from working.
Old Apr 4, 2017 | 10:14 AM
Yeah good thinking, I forgot about the switch on the clutch.
Old Apr 4, 2017 | 07:37 PM
MaddmaxxII's Avatar
Oh yeah, imma check those switches. Thanks a lot
Old Apr 5, 2017 | 10:04 AM
scottish's Avatar
SHINEY 8!!
Also check the reverse switch while your down there checking the neutral switch on the tranny as well. I'm sure that has something to do with the cruise control too.
My problem was the clutch position switch. The previous owner bypassed it with a bare piece of copper wire and took it to ground which did cure the problem temporarily but it failed two years later after I bought the car.
Dumb thing about it was that the car was a leased vehicle.
Old Apr 9, 2017 | 02:00 AM
MaddmaxxII's Avatar
OK will do and wow, he really did that on a leased car? I'd just let mazda fix it since it's least but the thing I don't get is why he bypass the switch? Bc wouldn't that not let it turn on or off?
Old Sep 28, 2017 | 12:04 PM
ch604's Avatar
the clutch has to be depressed in order to start the car, so my guess is that the switch was broken and he didnt have time to take it to the dealer. jerry rigged to let it start.
drebbrnator
Dec 27, 2018 07:02 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
GracefulShanks
Aug 18, 2015 11:40 AM
groll69
MW RX-8 Forum
Aug 17, 2015 04:21 PM
ion_four
Jul 30, 2015 09:48 PM
