View Poll Results: Which is the best and give more mileage?
Caltex
25.00%
Shell
46.43%
Esso
10.71%
Mobil
14.29%
BP
3.57%
Petronas
10.71%
SPC
14.29%
Project
0%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
Petrol mileage issue
Old Mar 11, 2006 | 11:51 AM
yohji's Avatar
人做到了其他人做不到的东西..我们叫他 ~~神
Thumbs up Petrol mileage issue
Hi all,I heard a lots of my frens telling me that shell petrol is the one can give u more mileage.Example: shell 50 dollar can go 300km
petronas 50 dollar can go 290km
caltex 50 dollar can go 260km
izzit true?since the petrol price is increase so i just want to find out which petrol can give our car more mileage n save our $$$$.
I seldom pump petrol at shell coz i always feel that petronas is the best so what u guys think and which petrol u all normally pump ,which petrol u guys feel is the best for car perfomance?Pls vote and give some comment....ur reply is important..thanks
Old Mar 11, 2006 | 11:54 AM
tan280's Avatar
orh jiao RX-8
for me I all the way use Shell cause all prices abt the same la... using unleaded 95 for now... so I hope this does help your choice...
Old Mar 11, 2006 | 11:58 AM
yohji's Avatar
but ah tan...shell really give the more mileage compare wif others?Some ppls said petronas lah,some said mobil lah.I really want to get the actual answer for this...hope all of u can share some experince...thanks anyway.
Old Mar 11, 2006 | 01:15 PM
4-TOOTH's Avatar
If you are talking about petrol in Malaysia .. I still think SHELL is the best power and the best mileage. But having said that Petronas new Primax comes second and it is in fact a very close second. Mileage diff is only about 50km diff most in one full tank. But if you are living in Singapore .. to pump petrol in Malaysia is so cheap even after the new price hike and even for the slightest gain I will still go for SHELL. Maybe I just dun quite like the name petronas. (Personal pref)
Hope it helps....
Old Mar 11, 2006 | 08:31 PM
lowrider's Avatar
A wanker with the Wenkel
I ahve tried the lot. i don't see any diff in mileage except in the prices of the gas. I thot Shell was good but then the next week it was average. The Caltex one week and it was good.... it really depends on your driving style. Try driving without using the brakes as possible. This will dictate (your petrol saving) new driving style. But not only save on $$ / gas but also brake pads!
Old Mar 11, 2006 | 10:27 PM
Emperor's Avatar
aka Spectre
Sometimes very hard to tell. Alot of factors affect power and FC. Cool days give more power, humid days less power, etc.
Old Mar 12, 2006 | 03:24 AM
sgrenesis's Avatar
THE GREAT WHITE
Also not forgetting is if you are driving on the NS highway most of the time. That makes a diff.
Old Mar 14, 2006 | 08:08 AM
yohji's Avatar
Thanks for the replys guy.Between slimer are u try to pulling my leg!!How many u vote for that...u almost vote everything from the list.I'm appreciate it so much.....
Old Mar 23, 2006 | 08:44 PM
Zard's Avatar
hey you guys actually tried using unleaded 95 on the rx-8? I know the 95 is allowed according to the manual but the damn agent keep insisting to use 98 unleaded. Any feedback on using the 95? if there is no problems then i can switch to unleaded 95 since damn fuel prices soaring so high.
Old Mar 23, 2006 | 08:54 PM
yiksing's Avatar
the giant tastetickles
You do realize that you are only saving a very little amount of money each time you fill up, I'm sure if you can afford a RX-8 in Malaysia you are pretty well off and shouldn't be worried too much about what to use. Just get the best RON as far as I'm concern expensive petrol is cleaner and helps keep your engine in tip top condition. Just so you know a full tank of Shell (from full till the last line on the fuel gauge) lasted me 450km.
Old Mar 23, 2006 | 09:02 PM
yiksing's Avatar
If the manual says 95, its perfectly all right to use 95. RON numbers dictates how fast the fuel combust, the higher the number the slower it combust. Higher RON thus allows more advanced timing in car engines without detonation while at the same time yield more power. Your car is most likely tuned for RON 95, eventhough you stuffed higher RON inside you will not get the benefit of higher power. However if you use something too low, the fuel combust too fast and the car's knock sensor will detect and retard the timing a little. You don't wanna rely on this coz you never know when your knock sensor is faulty. If you hear sound of "marble in a tin can" after you try lower RON, it means your engine is suffering from the knock.
Old Mar 23, 2006 | 09:05 PM
yohji's Avatar
Of course i understand that i can't save much money for that n of course i never concern about the money since as what u said if i can afford to buy a 8 in malaysia so i'm pretty well off.What i read from some others forum different pretrol give u a different mileage izzit true ?And which is the best?wat actually show at the poll now shell is the best....but sometime i really scared to go shell in malaysia coz got few case the outlet actually mix water wif the petrol...bloody hell imagine ur car down bcoz of the stupid action
Old Mar 23, 2006 | 09:06 PM
rotomotor's Avatar
This is only a suggestion. Although I have not owned a RX8 I had RX7's before, so with the Renesis engine I not very sure if it works. Train your RX8 by first going 50/50 of RON95/98 for 1 tankful; followed by 75/25 resp and finally 100% RON95. This way your ECU will slowly adjust to the lower octane fuel. However, if at any point your engine "pinks" (detonation) you have to go back to RON98. Considering the amount of savings it may be worth your while to try.
Old Mar 23, 2006 | 09:11 PM
yohji's Avatar
thanks for ur reply tiksing,i always tot that the higher the number the faster it combust...i going to try mobil 1 coz my fren told me it give more power for our car
Old Mar 23, 2006 | 09:36 PM
ed520's Avatar
i've always been on Shell, recently switched from 98 to 95 to save money....petrol getting bloody expensive!
My GF is also on Shell and when she tried SPC once, she reckons that Shell gives more mileage...
Old Mar 24, 2006 | 01:02 AM
Zard's Avatar
Thanks for the suggestion I think i'll give it a try.
Old Mar 24, 2006 | 01:28 PM
Rumboo's Avatar
Lurker
Dun worry, if not on FI, rotary can take low octane (89 oso can) without det. Numerous threads on this board have confirmed liao.
But the ECU training part might work..
Old Apr 1, 2006 | 02:12 AM
wAtOKek's Avatar
OMPM what ok
Been using caltex.
Will switch to Shell to give it a try after seeing the poll report.
Old Apr 2, 2006 | 12:36 AM
yiksing's Avatar
Your mileage has a lot to do with how you drive, seriously this is what I experiment with. As for water mixed petrol, it happens everywhere especially when the petrol station is located at low places and malaysia has some rainy seasons. I would put a higher RON if I can because I've read articles about expensive containing detergents, they burn cleaner and leave less deposit. I don't know how true this is but since it doesn't cost too much, I'll go with it.
WranglerFan
May 31, 2022 07:51 AM
Randolph Alvarez
May 30, 2016 01:08 AM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
MIGhunter
Sep 5, 2015 07:21 PM
