WedsSport SA-70 & Gram Lights T57-RC specs?
Old Mar 10, 2006 | 03:11 PM
Agent008's Avatar
Licenced to Race
Question WedsSport SA-70 & Gram Lights T57-RC specs?
Anyone know the specs on these rims:
WedsSport SA-70 18x8
Gram Lights T57-RC 18x8.5
I am looking for the offset and the weight of the rims.
I think I like the look of the SA-70's better but they both look pretty good too me.
Old Mar 10, 2006 | 03:23 PM
BigOLundh's Avatar
#1 Legend
I don't have specs on either of those. Have you checked wheelweights.net ??
Anyway, if you like those 2, you should check out the
Advan Connoisseur 51C
-hS
Old Mar 10, 2006 | 07:19 PM
http://www.weds.co.jp/products/wedssport/sa70.html
Old Mar 11, 2006 | 01:35 AM
SlowLude's Avatar
I ordered the SA-70s already!! Still waiting for them to come in...
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/cant-wait-my-rims-83778/
Old Mar 11, 2006 | 08:08 AM
Agent008's Avatar
Licenced to Race
Cool... Maybe you can put a rim on the scales before you install them.. I have been looking to find the weight of those rims for a while now. I hope they are as light or lighter then the TC-005 rims from Weds (17.7 lbs).
Old Mar 11, 2006 | 12:44 PM
unfortunately the offset on the 18 x 8 is not SCCA Stock legal
Old Mar 11, 2006 | 12:54 PM
SlowLude's Avatar
I did some searching and found a weight figure... 18.4lbs. http://forums.evolutionm.net/showthread.php?t=122016
These are casted wheels where I think the TC-005 are forged hence the bigger price tag. Hope that helps...
Old Mar 11, 2006 | 01:01 PM
that's a wider wheel with a different offset, doesn't apply
18 x 9 @ 35mm shown there vs 18 x 8 @ 42mm discussed here
Old Mar 12, 2006 | 08:55 AM
Agent008's Avatar
Licenced to Race
Yes, that extra inch width will mean more weight. I guess this is a good sign since it must be lighter then 18.4.. Comparing with the TC-005 at 18x9 (18.6) vs. 18x8 (17.7) there is a 0.9 lb difference. So it might be possible to assume that the SA-70 at 18x8 would be ~17.5 lbs.
An offset of +42 means the wheels will be extended 8mm outwards vs. stock (+50 offset). I guess that should not play too much havoc with the suspension geometry, I hope.
Old Mar 12, 2006 | 08:59 AM
that's not necessarily correct either, the Enkei RPF1 18 x 8 weighs 2 lb more than the same style in 18 x 9.5
you'll be ok with the offset change, it's not that signicant
200.mph
Dec 10, 2018 03:49 PM
CARBONRX-8
Oct 5, 2015 03:46 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
