View Full Version : RE8A-L NGK plug
florent75
02-12-2006, 04:26 PM
Hi,
I like to change the spark plugs with those ones : NGK RE8A-L (from canzoomer)
they are colder ...
could you give me the interessest for the rx8 the benefit
any danger ???
thanks
Razz1
02-12-2006, 04:28 PM
I would not go with a colder plug as the car runs pig rich.
Colder plugs will cause more fouling and harder starting, maybe even flood the car.
brillo
02-12-2006, 04:44 PM
I would not run the colder plugs unless you have a good reason to.
Mazda revised the regular leading plugs with a better design at the stock heat range. There is a TSB on finishlineperformance.com that details the part numbers.
If you are changing your plugs for the first time, you want to get the newer plug set. Someone had a group buy on the set for like $90, which is a good deal.
