Brake rotor replacement
Old Feb 8, 2006 | 03:04 PM
cgrx's Avatar
DRIVEN
Anyone know of a company that makes decent ones for a decent price ? and where they can be bought ?
Slotted/cross-drilled
Thank in advance !
Old Feb 8, 2006 | 03:21 PM
http://www.racingbrake.com/MAZDA_RX8_s/235.htm
Old Feb 8, 2006 | 09:02 PM
XeRo's Avatar
Normality is Obscene
r1concepts...they're on eBay...but you can contact them directly...i have their premium zinc plated rotors...but just slotted...holes in your plates can kill ya!! :D
irotors as well...they even resell Brembo discs.,..check ebay..most of the time you can get a steal on Brembo plates...they come already slotted and drilled...
clicky--> http://cgi.ebay.com/ebaymotors/Mazda...spagenameZWDVW
Old Feb 8, 2006 | 09:11 PM
cgrx's Avatar
DRIVEN
thanks all ~ !
Old Feb 8, 2006 | 09:29 PM
willhave8's Avatar
Originally Posted by TeamRX8
Do you know if these rust like the OEM parts? My objective is less braking improvement than it is cosmetic with no loss of performance for the HPDE days...
Old Feb 8, 2006 | 09:51 PM
joyridevr6's Avatar
0.19 posts per day
I have had the racingbrake two piece rotors on my car for a few weeks and I have not noticed any rust. I live in Chicago so the roads are salted on regular basis. I know time will only tell but the stock rotors rusted immediately. Hope that helps.
Old Feb 8, 2006 | 09:55 PM
cgrx's Avatar
DRIVEN
damn stock rotors
Old Feb 8, 2006 | 10:08 PM
willhave8's Avatar
I assume this is a pretty easy install? e.g. as easy as the fog light mod, changing wheels or I don't need MazdaManiac, RotaryGod, Hymee or Charles to help me??
Got any pics of them installed? I park my car next to a 330i, Audi TT and a Porsche 911 at work and my rotors are embarassing.
Old Feb 9, 2006 | 01:46 AM
The OE rotors are just painted if that, no special coating.
If you go to the RacingBrake rotor page link I listed earlier, you can see that there are two different finishes, depending on which rotor you choose. The silver hub ones are nickel plated, the ones with the black hubs have their unique EDP finish
Rotor is subject to rust and most rotors are not protected against corrosion in early years, it’s not uncommon to see a rusty rotor in a car dealer’s brand new show car. When we started our performance line about four years ago, we tried and experimented various surface coatings, and found EDP (Electro-Deposition Paint) gives optimal result in durability and cost.
Not only does EDP provide lasting protection against corrosion (about 500 hours salt spray test, vs. common bright zinc plating of 100 hours), it has appearing black look, more importantly it’s environmentally friendly unlike the competition using cadmium or gold zinc plating this metal coating process uses hexavalant chromium.
They coat the entire rotor, inside the vanes, etc. and then do a final cut on the disc braking surface
Old Feb 9, 2006 | 04:39 PM
joyridevr6's Avatar
0.19 posts per day
The hardest part of the install was removing the screws holding the front rotors on. This hurdle is easily overcome by having the correct tools. I used an impact tool to get my screws out (I am sorry I don't know it's specific name). They are fairly cheap and they sell them at NAPA. It is essentially a bit holder, which is built such that when you impact the end with a hammer it turns the bit while driving the bit into the screw thus preventing the screw from stripping.
Old Feb 9, 2006 | 06:03 PM
yep, without an impact screwdriver you are SOL on removing those screws. Fortunately I bought a cheapo several years back. Don't use it often, but it's saved my butt the few times I needed it.
http://www.harborfreight.com/cpi/cta...emnumber=46978
Old Feb 9, 2006 | 08:45 PM
joyridevr6's Avatar
0.19 posts per day
Thanks for the link. I used one that had been sitting in my fathers garage for some 15 or 20 years. It was in such a state that it would reverse direction on me after one hit and tighten the screw. Your right you won't use it that often but if you need it and don't have it you will kick yourself for not spending the 10 or so dollars to have it handy.
Old Feb 9, 2006 | 09:10 PM
You have your BBK kit installed, yes?
Old Feb 9, 2006 | 09:22 PM
joyridevr6's Avatar
0.19 posts per day
Yes, I installed it the first weekend after delivery. It has not given me any trouble as of yet although it was a bit more difficult to bleed than the conventional brakes. My next tool purchase is going to be a power bleeder for sure.
seb16
Sep 15, 2016 12:20 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
PotatoCannon
Sep 6, 2015 11:48 AM
Solidtrance
22
Sep 4, 2015 12:47 PM
Kahl
Aug 20, 2015 11:49 PM
