Power Loss: Blame it on the mouse?
Old Feb 5, 2006 | 10:49 PM
redsled's Avatar
Flashback to June 2004, right after I took delivery of my 6 speed. After a month of driving it rather softly, I noticed a problem in 3rd, 4th and 5th gears. Right at 6,000 rpms, the engine would strain as if heading into a stiff head wind. After two trips to the dealer, they apparently solved the problem by reflashing the computer. Never experienced the problem again until 18,500 miles (two weeks ago). Brought the car to the dealer and told them the sensation was the same. They replaced plugs and said that should solve the problem. It didn't. Brought it in next day. What they discovered was quite disturbing. Apparantly, a mouse decided to make a nest in my air intake system. The tech discovered my air filter was shredded and found sunflower seeds, wood shavings, newspaper and cloth scraps, and other not so nice things in the air intake. They cleaned it out best they could and also did an injector cleaning. Still, the car starts as normal, idles fine, but falls flat on its face at 6000 rpms.
Does anyone have any ideas? Oh yeah, I caught the mouse.
Old Feb 5, 2006 | 11:34 PM
bad cat.
secondarys not opening/ carbon build up.
motor failing.
Old Feb 6, 2006 | 12:51 AM
Big_Mike_4488's Avatar
350Z Killer
I'll be the first to admit that I don't know as much about cars as most others on this site. But how could a mouse live in there? Wouldnt it get sucked up or somethin?
So whatd the dealer say, are mice covered under the warranty?
Old Feb 6, 2006 | 04:02 AM
yiksing's Avatar
the giant tastetickles
Let's just hope your engine internals are not busted
Old Feb 6, 2006 | 04:20 AM
RichardK's Avatar
Another Filthy Mac User
From: Hawick, Scotland, United States of Blairland.
Originally Posted by swoope
bad cat.
What, for not catching the mouse?
You realise this is going to end up with a Horse in the intake, right?
Old Feb 6, 2006 | 07:41 AM
Ericok's Avatar
Rotary Wanker
The part about "cleaned out as best they could" does not instill a lot of confidence.
Old Feb 6, 2006 | 08:02 AM
expo1's Avatar
He's as bad as Can
Could be a CAT issue, have that checked to rule that out. I had a mouse issue also but found it before any damage was done. The Zapper in the photo has worked well at preventing that from happening again.
Attached Thumbnails Power Loss: Blame it on the mouse?-electronic.gif   Power Loss: Blame it on the mouse?-dcp1-small-.jpg
Old Feb 6, 2006 | 12:22 PM
Nubo's Avatar
Lubricious
As long as the MAF screen is still in place I wouldn't think anything big or hard enough to cause mechanical damage was sucked in, but that's just a guess. maybe some mouse dandruff binding up the VFAD ? But I think that symptom is more centered around 7250 rpm. The 6000 rpm lag is more often associated with a burnt coils problem or clogged cat, from reading the forums.
Old Feb 6, 2006 | 02:16 PM
redsled's Avatar
Bad mouse, bad cat.
Thanks for all the replies. I did forget to mention in my initial posting that the dealer checked compression and the psi readings were within spec. I thought this was a positive sign. They basically don't know what the issue is that is causing lag at 6k rpms and substantial power loss. No it's not very confidence inspiring.
Old Feb 6, 2006 | 02:43 PM
RichardK's Avatar
From reading, it really sounds to me like you have blocked ports.
Old Feb 9, 2006 | 10:24 AM
redsled's Avatar
Thanks to all who have offered suggestions. For an update, my dealer checked the CAT and has determined it is fine. They have been on the phone with the Mazda tech hotline and the next step is to warranty the coilpack. I should have the car back tomorrow to see if that fixes it. Will report back.
Old Feb 10, 2006 | 10:51 PM
yiksing's Avatar
Yeah definitely sounds like block ports or stuck ports.
Shankapotamus3
Mar 14, 2021 03:53 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
D13
Oct 1, 2015 07:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
