Broke My Lug Lock Key how to remove locks?
Old Feb 1, 2006 | 05:04 PM
slavearm's Avatar
Boost Junkie
Anyone know how to remove a lock if you have destroyed the key (long story that you don't want to hear) [ I am talking about wheel locks here folks]
Old Feb 1, 2006 | 05:13 PM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
Well, your problem is magnified 4-fold, since you will want to get a full set of the key and four matched locking nuts from your dealer. The dealer or a wheel/tire shop can then swap out the locking nuts.
is the wheel lock intact? (aside from destroying the key part)
OR
did you break the thing in half?
Old Feb 1, 2006 | 05:15 PM
RedSheDevil's Avatar
.:. causing mischief
all is not lost! i will search for the lug-saving thread that helped me get mine off. those things are CRAP! the KEY STRIPPED the LUG!!!!
brb with a link for ya!
Old Feb 1, 2006 | 05:36 PM
joyridevr6's Avatar
0.19 posts per day
Take it to the dealer they will usually take them off for free. I had to do the same thing a couple of weeks ago. They can order you a new key if they don't have yours in stock.
wow! that post was HARD To find in a search... here is a link to the direct post with the instructions i used to get mine off (my key/lug both stripped)
https://www.rx8club.com/showpost.php...29&postcount=3
here is the link to the whole thread ...
https://www.rx8club.com/showthread.p...t=lock+key+lug
hope that helps!
Old Feb 1, 2006 | 06:01 PM
slavearm's Avatar
Boost Junkie
1. The Lock is not in fact broken
2. It is not the factory lock... (its a nice titanium one)
3. I need to get them off so I can buy a new set, as the locks I have were picked up by my Brother-in-law in Japan (Navy)
4. The locks are not the star type (you know with the wacky shape on the top) they are a circle with 5 ribs on the side.
Thanks in advance.
Slavearm
Old Feb 1, 2006 | 06:18 PM
well if yer trying to salvage the lugs, i dont know what to tell you. maybe you can contact the manufacturer (that is, if you know who that is).
i don't know how else to get them off by yourself without ruining the lug by hammering a socket onto it.
good luck!
Old Feb 1, 2006 | 06:33 PM
slavearm's Avatar
Boost Junkie
I didnt think you could hammer a socket onto a spline lock? Maybe I am wrong
Old Feb 1, 2006 | 06:52 PM
kachud's Avatar
Mad Scientist
If you take it to the dealer they will use a air chisel and ruin your rim. I happened to me and a few others as well.
Old Feb 2, 2006 | 07:55 AM
09Factor's Avatar
Original Turbo 'd Auto !!
hope that helps!
Doh ! I forgot make a Diy for this!
Old Feb 2, 2006 | 08:45 AM
09, thank you thank you thank you for posting this procedure. you saved my *** on the day i found out my lug/key had both stripped. yes, make it a DIY for all those souls who think they are out of luck ...
Old Feb 2, 2006 | 09:47 AM
L8APEX's Avatar
Smooth Criminal
at this point, why use the locking lugs. If someone wants your wheels now, won't thye just swipe the car. I got rid of my dealer provided crap locking lugs. They only caused me trouble.
Old Feb 2, 2006 | 11:06 AM
connor@tirerack's Avatar
Forum Vendor
There are a couple of different option i would recommend.
If these were the factory locking lugs (i know they are not) you could call McGard at 800-669-6887. They will need some information from you and then they will send you a replacement key next day air normally for free.
Because these are a spline drive tuner style lug nut i may have a key that will work for you. We carry three different types of spline drive adapters and one of them may work. I would need to see a picture of the lug nut with some basic measurements: head diameter, number of splines. Give me a call if you would like me to look into this for you.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
