MTX Sledgehammer Enclosuers
Old Jan 28, 2006 | 12:53 AM
Imidazole's Avatar
Any opinion on these?
http://www.mtx.com/caraudio/products...ures/index.cfm
One of 'em, with subs, weighs 200+lbs!
Do you think thats noticible weight, that would slow me down a good amount?
Old Jan 28, 2006 | 07:33 AM
MrWigggles's Avatar
The problem with most MTX subwoofers (and this didn't used to be true) is their ridiculously high Qts values. Most of their current subs have QTS values that are around 0.7. Well that means you CANNOT make a box for them that has flat reponse. It is impossible since the box Q will be higher than the woofer's Qts.
Using an MTX woofer you are likely to have box with a Q of 1.0 or more (there are exact equations for all of this). That means you are going to get a lot of mid bass boom with very little bass extension. If you want to get loud, that might be good thing, but if you want to go deep - forget about it.
-Mr. Wigggles
JimmyBlack
273
Feb 10, 2020 10:23 PM
moete87
Sep 24, 2011 03:56 PM
moete87
Nov 21, 2008 12:06 PM
magikone69
16
Mar 15, 2008 12:01 PM
yellowRX
23
May 1, 2005 05:01 PM
