will the rx7 breaks fit on the rx8
Old Jan 27, 2006 | 04:58 PM
c41250n's Avatar
im just wondering will the rx7 4 pot break fit onto the rx8?
if not, what are the good aftermarket breaks out there?
Old Jan 27, 2006 | 05:03 PM
expo1's Avatar
He's as bad as Can
Been discussed before https://www.rx8club.com/series-i-tech-garage-22/fd-rx7-front-brake-calipers-72853/
As for the aftermarket here is one site http://www.racingbrake.com I don't have their brakes but have been to their shop.
Old Jan 27, 2006 | 05:45 PM
VBprogrammer666's Avatar
Sorry, I can't resist:
Brakes are what stop your car.
Break is what happens to your beer mug when it falls on the floor.
Old Jan 27, 2006 | 08:00 PM
MazdaManiac's Avatar
It is nearly impossible to improve upon the OEM braking system on the RX-8. It is already superior to the aftermarket solutions that were offered for the 7.
Most of the aftermarket brake manufacturers have found that they loose performance with bigger calipers and rotors.
At best, you might break even.
There. I used "brake" and "break" in one post without being demonstrative.
No, what happens then is "cry".
Old Jan 27, 2006 | 10:24 PM
murix's Avatar
Here is a good brake upgrade that will not break the bank.
Old Jan 28, 2006 | 12:39 AM
nolarx8's Avatar
the brakes you have are good but if you must replace from experiance (project u) fits,looks and works great
Old Jan 28, 2006 | 05:00 AM
c41250n's Avatar
the only reason why im think of upgrading the brakes is because i wanted to put a turbo kit into my car, so im guessing a better braking system is recommended.
Old Jan 28, 2006 | 08:11 AM
Okay, I know I'm a jerk but (emphasis added by me in the quote)- -
Loose - not tight
Lose - What's going to happen to my front teeth if I keep correcting everyone's grammer when you all beat the crap out of me.
Old Jan 28, 2006 | 01:25 PM
Gord96BRG's Avatar
Let's try again. The stock RX-8 braking system is excellent. Better than just about ANY other stock brake system out there. Better than most aftermarket brake systems, which usually degrade brake performance.
If you want to improve braking performance - invest in stickier tires; flush the brake fluid; find out from the track guys which performance brake pads to fit. If you want bling - then "upgrade" the brakes.
Old Jan 28, 2006 | 01:33 PM
Loose - not tight
Take a step back and enjoy the irony of my entire post.
Old Jan 28, 2006 | 01:55 PM
JRichter's Avatar
Void Where Prohibited
Nice tread pattern. What kinda of price are we talking?
Old Jan 28, 2006 | 05:34 PM
Ike's Avatar
Ike
Blue By You
The RX-8 has very nice brakes but lets not go overboard... Most top quality brakes are going to be an improvement on the track even if they don't improve the car numbers wise in some mag test.
To the original poster, from the sounds of it you're not some track junkie so most people telling you to not bother spending money on brakes are correct. The RX-8 once turboed isn't so powerful that the car needs better brakes.
If you insist on getting some nice aftermarket brakes check out Brembo, Project Mu, Endless, Stoptech, or Wilwood.
Old Jan 28, 2006 | 06:43 PM
therm8's Avatar
Bummed, but bring on OU!
The only reason I see for someone who doesn't track the car alot to change the braking system is for lowering unsprung weight (and asthetics too I guess). Swapping out rotors and calipers all the way around to stock sized aftermarket stuff can reduce this weight by about 40-50lbs (based on weights given by RacingBrake in a thread in the Competition forum). With a lightweight wheel/tire combo, this is some serious, if expensive, weight reduction, and braking performance should at the very least stay the same. Heck that's a good reason for someone who tracks the car to change the braking system.
Old Jan 28, 2006 | 06:49 PM
I did enjoy you're post. But my need to be a jerk exceeds my ability to enjoy you're post. My therapist is working with me on this problem.
Old Jan 28, 2006 | 11:35 PM
But, sometimes one uses homophones for creative (or, in this case, pejorative) purposes.
Old Jan 29, 2006 | 02:54 AM
c41250n's Avatar
thanks for all the opinions, i think im just gonna stick with the stock breaking system, and maybe just change the brake pads and the rotors!!
Old Jan 29, 2006 | 09:06 AM
automaton's Avatar
Most people that track their cars say that the RX-8 has one of the best stock braking systems on the market. For upgraded braking you should be able to swap out the pads for some Hawk HP+ pads install braded steel brake lines and put some high temperature brake fluid in after flushing out the old stuff.
That should do nicely, and it'll all only cost a couple hundred bucks.
good luck.
Old Jan 29, 2006 | 10:42 PM
c41250n's Avatar
thank you very much!! thatz why im gonna do now!!
Old Jan 30, 2006 | 07:44 AM
Section 8's Avatar
If you want to improve braking, get some sticky tires, decent pads, and stainless steel lines. If you can lock the tires (or in case of these cars trigger the ABS) your brakes are working fine.
Old Feb 1, 2006 | 04:52 PM
arghx7's Avatar
sticky tires are crucial
Old Feb 1, 2006 | 05:04 PM
DrKillJoY's Avatar
Pssst... it's "grammar" not "grammer".
Old Feb 1, 2006 | 05:58 PM
Bastage's Avatar
DEVILMAN
beat me to it
I was just about to say "but at least he can probably spell "grammar"
Oh well...
Old Feb 1, 2006 | 07:44 PM
You win the prize. I purposely have added grammatical/ misspelling mistakes in my last couple of posts.
But you missed my use of you're instead of your. I did it twice in one post.
Old Feb 2, 2006 | 12:46 PM
DrKillJoY's Avatar
:D
Only pointing out one thing at a time... I didn't wanna look like a total *****. :D
Old Feb 2, 2006 | 08:22 PM
:D
I guess we've totally hijacked this thread with this silliness. Sorry, I'm done. Time to get back to the RX-7 breaks.
F51
Aug 2, 2021 04:07 AM
madrotor
Jul 26, 2015 12:06 PM
KingBonacci
NE RX-8 Forum
Jul 22, 2015 11:25 PM
RX7.9
Jul 20, 2015 12:01 PM
