How does the RX-8 hold up in the heat?
Old Jan 20, 2006 | 12:19 PM
DailyDriver2k5's Avatar
The Prototype
Being in FL, i was wondering if any of your owners who live in the south have had any overheating issues with the RX-8 in the summer time? Its get pretty hot here in Central Fl, and being this is my first rotary, i heard rumors that the rotary doesn't do so hot in the summer time. Is this true guys?
Old Jan 20, 2006 | 12:20 PM
guy321's Avatar
Humpin legs and takin nam
I've never had any overheating issues so far and I purchased my car in Sept 03.
Old Jan 20, 2006 | 12:27 PM
msrecant's Avatar
Hubble has been saved!
The only overheating has been in the cabin. The AC seems to only be effective on recirculate.
In 30 months, and a variety of weather/driving conditions up to the low 100s, I have never had any issues with engine overheating.
Old Jan 20, 2006 | 12:30 PM
guy321's Avatar
^^ True, but I've never had a car where the AC blew ice cold in 98 - 103F weather without being on recirculate..
Old Jan 20, 2006 | 12:46 PM
msrecant's Avatar
Unfortunately, my RX-8 doesn't blow ice cold at 75F without being on recirc. One hopes that that is something Mazda has improved since my car was built.
Old Jan 20, 2006 | 12:47 PM
Papapump51's Avatar
ROSSIFUMI GAMBATTE !!
NO problem here....ummm and just an FYI MSRECANT...when you are in the high heat the only way to get that cold air is to recirculate...because if you have it on th eother settign it is bringing in the 98 degree air, plus more engine heat , then your AC is trying to cool it down....the recirculated air keeps getting cooler as it passes though....
Old Jan 20, 2006 | 12:52 PM
bluesunlion's Avatar
my other car is blue
No heat issues here.
Old Jan 20, 2006 | 01:29 PM
mrkinn's Avatar
ZOOOOOOOOOMZOOOOOOOOOOOM
A Okay In Naples Florida!
Old Jan 20, 2006 | 01:32 PM
OptimusWang's Avatar
I love my RX8, and I'm in Orlando. Gas milage sucks, but that's expected.
Old Jan 20, 2006 | 01:47 PM
LiveToRev's Avatar
Bah! Who needs a redline?
No overheating issues here either. I'm in Broward county.
Old Jan 20, 2006 | 02:00 PM
The Prototype
Good to hear! Thats great guys...
Old Jan 20, 2006 | 02:04 PM
blue flash's Avatar
my ac does not put out very well unless you are moving.stopped @stop lights it gets hot in here.
Old Jan 20, 2006 | 02:30 PM
no issues here, 3 1/2 hour drive from L.A. to Las vegas in 113 degree weather with ac turned up, no problems. I also wrapped my ac line with thermal wrapping.
Old Jan 20, 2006 | 03:03 PM
JonsToy's Avatar
Registered Rep
The 8 works just fine in the Central FL heat. The only difference you'll notice between driving in the winter and the summer is the thermostatically-controlled radiator fan stays on after you work the car out in the summer heat. Keep an close eye on your coolant level, too.
The problems you're referring to seem to be confined to very hot (above 110 deg) and very dry (Vegas, TX) climates.
Old Jan 20, 2006 | 04:57 PM
alchemist's Avatar
I drove mine all last summer in Phoenix without any problems. Several days were above 110°! Don't be surprised if your fan runs for several minutes after you shut the engine off when the temps are high.
Old Jan 20, 2006 | 05:22 PM
GerryL's Avatar
Gerry
Mine has done fine in Southern California summer weather. It does help to thermally wrap the AC line as mentioned in a previous post. I think the underhood area doesn't evacuate the heat well in stop and go traffic despite the cooling fan. The cooling system does fine but the AC suffers a bit in mid summer stop and go.
Old Jan 20, 2006 | 05:25 PM
cleoent's Avatar
n00b
You're fine. The auto 8's that dont get their legs stretched enough were having some problems in hotter climates like Las Vegas, but i've heard of no such problems with the 6 port version.
Ian_D
Rotary Swaps
26
Jan 21, 2017 02:23 PM
motohegg
Aug 23, 2015 08:14 AM
dafiltafish
Aug 21, 2015 06:56 PM
thewatcher101
Jul 27, 2015 09:44 PM
vssystemluba
Jul 19, 2015 04:16 PM
