6 speed automatic gear ratios?
Old Jan 19, 2006 | 01:45 PM
MikeW's Avatar
Does anyone know the gear ratios of the 2006 Rx-8 6 speed auto?
Would they be the same as the Mx-5's?
How about an axle ratio too.
Thanks.
Old Jan 19, 2006 | 01:50 PM
StealthTL's Avatar
Metatron
Post Ratios.....
Sorry, can't help with the gears, but the rear end is the same (4.44) and may not have the LSD.
S
Old Jan 19, 2006 | 02:27 PM
saturn's Avatar
i pwn therefore i am
According to the 2006 spec deck (https://www.rx8club.com/attachment.p...chmentid=67529) here are the numbers for the automatic (column 1) and manual (column 2):
1st - 3.358 - 3.760
2nd - 2.060 - 2.269
3rd - 1.404 - 1.645
4th - 1.000 - 1.187
5th - 0.713 - 1.000
6th - 0.582 - 0.843
Reverse - 3.168 - 3.564
Final Drive - 4.300 - 4.444
Old Jan 19, 2006 | 02:29 PM
zoom44's Avatar
saturn did you have any issues accessing the pdf?
Old Jan 19, 2006 | 02:31 PM
saturn's Avatar
No, I'm able to bring it up just fine. Pretty sure I got the link from a post you made. Not sure if it's appropriate to post a link to an attachment in a different post. I (or you) can change it if you want.
Old Jan 19, 2006 | 02:35 PM
zoom44's Avatar
no no its fine i just cant seem to open the pdf - my pc just bogs. in fact ive had this issue alot lately....
Old Jan 19, 2006 | 02:42 PM
snizzle's Avatar
Shakezula, the Mic Rula
no no its fine t just seem to open the pdf - my pc just bogs. in fact ive had this issue alot lately....
Adobe Reader is just frickin' slow sometimes. You can delete a lot of the plugins that come default that will help load times. Also, if you save the PDF locally and then open it outside the browser it'll help as well.
Old Jan 19, 2006 | 04:53 PM
zoom44's Avatar
you know i was having trouble since an update awhile ago. i then today updated to 7.0.5 and that didnt fix it- if anything it got worse. ones on my pc wouldnt even open.
so just now i uninstalled the update and went to the firefox plugin page. downloaded and reinstalled 6.0.2. everythign fixed !! they allopen no problem now.
actually ima start a lounge thread about this
Old Jan 19, 2006 | 05:16 PM
any one notice the mpg difference!!!!! i will bet it gets more than that.
Dokuji
Nov 1, 2016 02:51 PM
reni04
Aug 21, 2015 01:33 PM
nnsoch1776
Jul 22, 2015 04:16 PM
