Air Injection Pump
Old Jan 17, 2006 | 10:41 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Air Injection Pump
It's 10am in the morning and about 60F outside. I walk outside get in my car and start it. What do I hear "weeeeeeeeeeeeeeeeeeeezzzzzzzzzzzzzzzzzzzzzzzz z" for about 1 minute. It has been this way for as long as I can remember, but it seems pretty damn loud. Is that normal?
For those of you who don't know, the secondary air injection pump circulates warm air from the exhaust into the intake to help meet emissions during cold starts.
Old Jan 17, 2006 | 11:42 AM
ucfracerx8's Avatar
Pistons are Over Rated
Yep, mine has always done it. The colder it is when it is first started, the longer it seems to run for. I have not timed it to see if this is actually true, or if it simply runs for a set amount of time at Start-up. Maybe Zoom or RotaryGod knows for sure. I typically wait until it stops to move the car, I use the wheeezzz stop as my warm up guide, once it shuts off, I keep the RPMs under 4k until the temp is up to the middle and then drive normally.
Old Jan 17, 2006 | 11:45 AM
MazdaManiac's Avatar
^^ This is exactly my warm-up schedule and what I recommend to every one.
The amount of time the pump runs does change according to temp, though I haven't seen any data in the shop manual to indicate what criteria the PCM uses to decide how long it should run, if at all.
30 seconds is typical.
Old Jan 17, 2006 | 12:19 PM
xrider01's Avatar
127.0.0.1
i don't think i've ever heard that. i always hear the clutch over everything else.
Old Jan 17, 2006 | 12:25 PM
It sounds like a mini vacuum cleaner. Next time your car is stone-cold, pop the hood before you start it and get out and listen to the device just in front of the windscreen washer bottle.
Old Jan 17, 2006 | 12:40 PM
Makes the car sound like it has a jet engine under the hood.
Old Jan 17, 2006 | 01:23 PM
xrider01's Avatar
127.0.0.1
lol....i'll do that then. i gotta add a quart of oil today anyways, so i'll have the hood open
Old Jan 18, 2006 | 11:09 AM
Imidazole's Avatar
My old Camaro had the same exactl air pump sound.
Old Jan 18, 2006 | 11:37 AM
RenKat's Avatar
The air injection pump puts fresh air to the Cat until the Cat reaches light off temp.
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
Jul 9, 2016 07:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
