TPMS Light error?
Old Jan 16, 2006 | 12:40 AM
rollerbldes's Avatar
TPMS Light error?
Is it possible that the TPMS is detecting my pressure as low because the temperature was low today? I started the car, ran for about 5 seconds and TPMS started beeping. I'm guessing it's because of cold weather. Anyone else experienced TPMS light because of cold weather?
Old Jan 16, 2006 | 12:42 AM
tiggerlee's Avatar
May Cause Anal Leakage
Did it eventually go off after the tires were warmed up?
Did you check your tire pressure?
Old Jan 16, 2006 | 05:48 AM
Go48's Avatar
Yes, the TPMS is probably indicating low tire pressure that may be due in part to cold temps. The colder the temp, the slower the air molecules move hence lower pressure (or something like that anyway ). Check your tire pressures regularly with the tires cold and inflate them to the recommended pressure. Tire pressures usually will vary a few lbs as the outside temperatures change.
Old Jan 17, 2006 | 06:47 PM
Yep.. this afternoon it was warm, after I drove around a bit the light went off. Thanks for the comments.
Old Jan 17, 2006 | 07:21 PM
zoom44's Avatar
always check the pressure when cold(mornings before driving) and and using that measurement add or subtract the amount needed to bring them to the proper psi. for the potenza's on the rx-8 that is 32 psi
Old Jan 17, 2006 | 09:55 PM
Mine came with Dunlop SP Sport. I think the 32psi still applies though.
05rx8mazda
Nov 28, 2015 09:42 AM
CARBONRX-8
Oct 5, 2015 03:46 PM
drlubell
Sep 26, 2015 11:58 PM
Evan Gray
Sep 26, 2015 12:30 PM
