Gearbox Noise changing into 2nd
Old Jan 15, 2006 | 07:13 AM
Prototype's Avatar
Does anyone else get a noise when changing into second and speeds higher than 9mph?
Sounds like a syncro spinning up. Gear change is still smooth and crunch free but this noise is annoying me.
No noise when cold, worse the hotter and longer I have been driving
I did read some posts about people using short shifters having more noise. I dont have a short shifter but I do have an illuminated gear ****.
I beleve the noise got louder after fitting it. I have checked the fitting and all the insulators are still in place asuming they are there to cancel out transfered noise from the gearbox.
I was thinking of changing the gearbox oil to Redline MT90
Thoughts anyone???
Model RX8 231 - 2500 miles September 2005 - UK Spec -
Old Jan 15, 2006 | 09:14 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
Probably sychros-change fluid anyways.
Old Jan 15, 2006 | 09:44 AM
Go48's Avatar
I seem to recall a few threads reporting the same thing as a known issue. Do a search and read them.
Old Jan 15, 2006 | 10:05 AM
Ole Spiff's Avatar
I switched to Royal Purple and could not believe the difference it made in the noise level coming from the transmission. I didn't realize it was that noisy until after the oil change.
Old Jan 15, 2006 | 11:43 AM
Prototype's Avatar
Hi Go48, I did search this problem but could only find topics relating to either noise when in Neutral or transmission noise after changing to a short shifter.
Maybe I was searching the wrong keyword - Perhaps you can help me find the topic please
Old Jan 15, 2006 | 12:47 PM
epitrochoid's Avatar
Riot Controller
it's normal (in the sense that everyone has it)...it's a million times louder with the AFE short shifter installed, since it eliminates the factory damper.
Old Jan 15, 2006 | 12:51 PM
Prototype's Avatar
Ok as long as its normal im happy again
I was sure I never heard it before tho just in the last few weeks.
Will be changing the oil for Red Line MT90 anyway after reading other posts
Old Jan 18, 2006 | 07:48 PM
lshu's Avatar
Driving makes me :)
Good choice! I changed my fluid to MT90 and it was a huge difference for the tranny noise. Not only that, the tranny shifts like it's suspended in butter... mmmmm... butter...
Old Jan 19, 2006 | 12:22 PM
Prototype's Avatar
What sort of noises were you getting before you changed your oil??
RevMeHarder
Jun 1, 2026 02:30 PM
Azki23
Jun 27, 2018 03:48 PM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
