Dampners on the Shinka
Old Jan 10, 2006 | 12:54 PM
delrmx01's Avatar
I'm looking into getting some lowering springs for the 8 but I had a question--the Shinka has bigger dampners than the other 8's right? Would this affect on how the aftermarket springs fit?
Thanks for your help !
Old Jan 10, 2006 | 04:23 PM
delrmx01's Avatar
Anyone know? Pleeeeaasssee?
Old Jan 10, 2006 | 11:12 PM
DOMINION's Avatar
I don't buy Kool-Aid
Sorry man don't know.
Old Jan 10, 2006 | 11:16 PM
GeorgeH's Avatar
I seriously doubt the dampers are so large that they would requure larger diameter springs. The perches might be a different size, though.
Heres a thought. Call a Mazda dealer and tell them you need some new springs for your Shinka. Ask them if the Shinka springs have a unique part number as compared to the normal sport springs. If not, you know you are safe.
Old Jan 11, 2006 | 08:26 AM
Umbra's Avatar
I wouldn't bother with the shinka shocks. They are still not strong enough for the car, the back end is still floaty under heavy loads and there is still a fair amount of body roll.
Get some decent after market shocks you'll be far better off.
Old Jan 11, 2006 | 09:25 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
They are talking about the piston shaft size, 12mm vs 10mm, it wont have any affect on the springs you chose. The strange thing is the Mazda factory parts book does not have a part # for the Shinka. They list a standard and a sport but that is it. I wonder if they could be using the MazdaSpeed shocks on the Shinka..... Only one way to find out, someone pull the part # off of a stock Shinka shock.
Old Jan 11, 2006 | 09:37 PM
they're still crap compared to any decent performance shock
Old Jan 22, 2006 | 10:02 AM
sakura968's Avatar
Long Lost Rotary Brother
It is the internal piston size that is the difference, not anything external. And it is 14mm (Shinka) vs. 12 mm (stock). I do not think it will make any difference when choosing springs, but a part number cross-reference will answer any of your questions.
Mazdaspeed Fr.: QSEA-34-700
Mazdaspeed Rr.: QSEA-28-700
Old Jan 25, 2006 | 12:27 PM
sakura968's Avatar
I ammend my first statement: It's 14mm vs. 12.5mm.
Also, I checked AllData, a industry database that contains manufacturer's part numbers and prices. They do not have Shinka numbers, which most likely means that Mazda has not published them. Maybe one of the Mazda tech members would know?
LB2739
Jul 9, 2019 02:25 AM
Tgiolitto100
Sep 29, 2015 10:52 AM
Counter_Glockwise
Sep 21, 2015 06:51 PM
Von Walker
Sep 13, 2015 03:54 PM
Tsurugi
Sep 7, 2015 08:27 PM
