zee2000rx8
01-02-2006, 06:29 PM
I'm in Montreal,Qc. When starting my 8 at minus 10 and colder the motor is reving up at 4000rpm for about 20 to 30 seconds, after is dropping back to 2000rpm The sound is howful. It's like a bird stuck in the rotor. I never saw a motor running so wild because it's cold. Any hint ?
thanks
BlueFrenzy
01-03-2006, 01:45 AM
That's normal behavior. It's the PCM's way of protecting the engine and to get the temperature up.
If it bugs you that much ... you can give the gas pedal a little blip, that will allow the revs to come back down to ~1000.
Shamblerock
01-03-2006, 03:02 PM
My used to do the same thing with the M Flash, but now not more than 2,000 RPM with the "R" flash. Mind you, we only had 3 or 4 days where it went to -11, so can't be 100% sure just yet.
zee2000rx8
01-03-2006, 08:56 PM
I'm doing the tank fuel recall this week and if my mazda garage is serious he is suppose to update my PCM. thanks for the respond.
StealthTL
01-03-2006, 09:01 PM
Yeah, mine used to do that with the M flash, and it hasn't done it (so far) with the new R flash.
The flash is a part of the fuel tank recall - don't go home without it!
S
04RX8chk
01-04-2006, 03:02 PM
Interesting - I had the fuel tank recall done in the early fall, but my car has done this anyways - but only when it is really cold (-20 degrees).
Marc_GS
01-04-2006, 03:34 PM
Same here. I just got my car in September, and the tag showing the recall was performed was on the car when I got it. One very cold morning a few weeks ago it revved to 4000+ for a couple of minutes when I started it. I looked on this forum and saw that a lot of people have experienced the same thing, so I'm not too concerned about it.
rotten42
01-04-2006, 04:13 PM
It's nothing to be concerne with
Admiral8
01-04-2006, 05:06 PM
I had the same concerns too during cold weather.
My car was doing the exact same thing.......
Now, I think it's kinda cool........it's like the car is growling in the morning just getting outta bed!
