Replaced RB Sways/Springs with Stock
Old Jan 2, 2006 | 11:16 AM
Hotsauce's Avatar
RRDI Member
Has anyone out there with RB sways and springs switched back to stock? And why? Didn't like the ride on the street? Too Stiff?
Old Jan 2, 2006 | 11:55 AM
rev-2-9k's Avatar
Space Cadet
I have this setup and was only thinking of adding the Koni's. I like the ride and will not switch back.
Old Jan 2, 2006 | 12:44 PM
BigOLundh's Avatar
#1 Legend
if your having issues with this setup its probably due to the fact you didnt change your shocks.
Old Jan 2, 2006 | 05:21 PM
Hotsauce's Avatar
RRDI Member
I'm currently running stock suspension, and I have a modification itch. I already have RB Revi/Ram Air and oil cooler screens. I've heard the next best mod is RB sways and springs for the 8. I tend to agree, I notice body roll on fast hard turns. I don't want to sacrifice the ride of the 8, don't want it to ride like a 350z.
I want comfort on the higways and my short commutes to work, but mimimal body roll during aggressive driving.
If I did get the sways and springs, why would I replace the shocks?
I can see replacing them if I did a alot of track time and autocross.
Old Jan 2, 2006 | 05:51 PM
The stock dampers are valved to be compatable with the stock springs. If you make the springs stiffer....your dampers won't work properly. The RB springs have been designed to not be that stiff...and will work OK with the stock dampers...but The Koni's are adjustable and will give you better performance......
It all boils down to how much you are wanting to spend for the performance you want.
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
Espo
Aug 11, 2015 07:11 PM
cschoeps
Aug 6, 2015 12:44 PM
