Am I doing something wrong w/ Emanage?
Old Dec 29, 2005 | 07:05 PM
MarWar80's Avatar
I am trying to install the Greddy Emanage Support Tool, but i cannot get it to communicate with my Lap Top. I have tried several computers but no Luck. All I get is "OFFLINE" on the bottom right of the Emanage Screen. I have version 1.20/1.40. Can anyone help. I remember I was able to do it once when I first got my Greddy Kit, but i no longer have that computer.
Old Dec 29, 2005 | 08:20 PM
Japan8's Avatar
Int'l Man of Mystery
You are doing something wrong. You are posting in the wrong forum. This should be in the emanage section of the Aftermarket Parts and Mazdaspeed forum.
Mods?
Old Dec 29, 2005 | 09:41 PM
adrian-1's Avatar
Ex- member.
Check to make sure it's the correct port. Since it's a differrent pc, they may not be setup correctly.
-right click "my computer"
-click on properites
-select "hardware tab"
-select "device manager"
-look under ports tab and see where it's connected to.
Then setup the emangae support software to the same port (COM1,COM2,etc..)
This is probably the problem. I doubt it's a software rev issue since you said it worked before.
Old Dec 29, 2005 | 09:46 PM
MazdaManiac's Avatar
Check the COM port assignment.
Old Dec 30, 2005 | 06:54 AM
MarWar80's Avatar
One thing that I failed to mention is that I don't have the 9prong serial port on my laptop. I have an adapter that from the greddy wire that converts to a USB PORT. I called benny at Greddy, he says that the adapter should work. However my computer is not recognizing the hardware. Do any of you, know what driver I should be running? Or where I can get it?
Old Dec 30, 2005 | 09:26 AM
The driver that came with the serial to USB adapter should work just fine.
Once again, check the COM port assignment in the Support Tool and make sure it is the same as what the serial to USB is reporting.
ztuner
Series I Engine Tuning Forum
Sep 19, 2007 04:11 PM
geracing
Oct 24, 2005 11:54 PM
hosrom
Oct 23, 2005 09:42 PM
