Urgent Please Help
Old Dec 26, 2005 | 06:31 PM
rx8gurl's Avatar
Urgent Please Help
hello, I am currently taking off the REVi intake I had and putting the oem one. Everything turned out good, except there is a tube that seems to be cut off and I do not know where it should be reconnected.
I do not have the REvi instructions so I cannot look at them, does anyone know where this goes??
I am literally in the garage and my buddies are waiting for me. Anyone have any info, thanks
Old Dec 26, 2005 | 06:46 PM
What does it look like ........could be a lot of things??
Moostafa29's Avatar
Storm Trooper
Tube that is cut off? Does it look like an accordian (spelling)?
Old Dec 26, 2005 | 06:48 PM
rx8gurl's Avatar
no its just a regular small black tube. It is connected to this sort of little black cylinder (boxy) looking thing thats about 2x1.5 inches. It is right next to the air flow sensor.
Old Dec 26, 2005 | 06:49 PM
small tubes are Vac tubes to the VFAD duct. Large tubes are the MAF tube and the connector to the throttle body( accordian tube)
Old Dec 26, 2005 | 06:58 PM
Nemesis8's Avatar
Bigus Rotus
Can you post a photo?
Old Dec 26, 2005 | 07:54 PM
StealthTL's Avatar
Metatron
Tubing.....
You need about a foot of tubing, it connects the black cylinder to the throttlebody. You will see a small metal pipe it connects to, just behind and under the silver square throttle.
S
Old Dec 26, 2005 | 08:00 PM
QBallz's Avatar
Heres a pick from the shop manual.
Old Dec 26, 2005 | 09:38 PM
rx8gurl's Avatar
wow, this could have been so f-in helpfull about an hour ago. well now i know what i need for tommorow bright n early. Thanks Qballz.
I do not know if any numbers are pointing to it. But its the dotted line that goes from that cylinder under the filter box. And passes numbers 12 and 4. Someone here said I needed about a foot of tubing, how do I know what size tubing and where can i buy this??
two other quick questions.
For the unit number 6 is pointig to. Not just the little bronze plate, the whole tube (vfad?). Is it supposed to connect securely to the filter box, because I cant seem to make anything click.
And alos, does anyone know what size bolts those are holding that same piece to the car, I seemed to have lost them, thanks alot guys
Old Dec 26, 2005 | 11:27 PM
rx8gurl's Avatar
anyone, pleaseeeeeeeeee. I really need ur expertise guys
Old Dec 26, 2005 | 11:33 PM
back under the throttle body is where it connects... you should have a red cap on it right now,,, you should have put it on when you installed the revi....
if that dosent make sense or you cant find the red cap i will try to photo for you...
Old Dec 27, 2005 | 03:06 AM
rx8gurl's Avatar
thanks i think i got it swoope. these are my main questions now. especially the first one, thanks alot
And also, does anyone know what size bolts those are holding that same piece to the car, I seemed to have lost them, thanks alot guys
Old Dec 27, 2005 | 03:21 AM
Detrich's Avatar
幹他媽!
Just a suggestion.... Use your digital camera to take a quick shot when u post these kinda questions, because it will make it easier for people to see what you're asking about.
Old Dec 27, 2005 | 07:04 AM
Moostafa29's Avatar
Storm Trooper
^Also try labeling the hoses you take off, if you can't remember where they go. Would save you a lot of time, and you could be driving now.
Old Dec 27, 2005 | 03:27 PM
rx8gurl's Avatar
haha yea i figured that one out by now, hehe
Old Dec 27, 2005 | 04:47 PM
Nemesis8's Avatar
Bigus Rotus
I have the REVi install doc as a PDF, but it is HUGE. I can e-mail it to you if you like, just drop me a PM.
Old Dec 28, 2005 | 10:57 PM
rx8gurl's Avatar
i know what it is and where it goes now. I could not find a tube that would fit so I am planning on driving to the dealership like that and ask them to replace it. Is this a not so smart idea, will they give me BS for driving like that?
It wasnt necessary for the REvi, so it cant be that bad, right?
Old Dec 28, 2005 | 11:01 PM
not really a big deal it just opens up the vdaf flap under full throttle. let me see if i can get a pic for you.
Old Dec 28, 2005 | 11:27 PM
ok,
here you go. standing on the pass side in front of the wheel. look at the first photo it should look the same.
you do not have the red wire running in the photo.
you should see the red cap the is just above where the two larger rubber hoses cross, above the zip tie holding the red wire you dont have.
that is where the hose connects you can also use the silver that attaches to the plastic intake manifold as a reference.
pic 2 is a closer shot.
hope this helps.
Attached Thumbnails Urgent Please Help-dscf1384_edited.jpg   Urgent Please Help-dscf1385.jpg
Old Dec 29, 2005 | 12:44 AM
rx8gurl's Avatar
thanks alot
Old Dec 29, 2005 | 01:38 AM
Armaant's Avatar
Armaan
hey,
Just to be safe I would stay away from the dealership for now from what I now though this post might be a bit late. Also most of the bolts within the engine compartment are 10mm. From what you told me you should still have the vfad installed unless the revi requires you to take it out....Anybody know for sure???
Also where are we on the speakers?
theboy
May 24, 2007 03:33 AM
titaniumgrey
NE RX-8 Forum
Jun 12, 2004 09:59 AM
