nedor
12-23-2005, 09:10 AM
I was not able to find similar threads and I am hoping someone can help me.
Yesterday, my 3 weeks old baby with 1000 miles got sick. I was stuck in traffic for good 30-40 Min. I must have done maybe 1/2 mile during that time. The car probably moved 5 feet before I pressed the clutch to move the gear from 1st to netural. All of sudden, I felt a huge jerking motion as if someone rear ended me. I immediately looked down at the gauges after seeing that the rear car was not even close to my rear. The RPM was slowly coming down from around 1500. Since this incident, I am having following problems.
1, 2, 3rd gear is whining, grinding and rattling. Rattling noise can be also heard in 4th gear. Sometimes, I have to slighly force the gear in and one time, I was not able to put in to the 2nd gear.
Clutch no longer grabs when releasing it to get the car in motion. Before, I was able to at least slowly depress the clutch and somewhere before it got to 1/2 way, clutch grabbs the gear. Now it grabs the gear way after 1/2 way. Also, clutch and gas action became a problem. I have to press the gas paddle more or car will stall.
I also noticed something from the rear is moving around. When coming to a full stop, it feels and sounds as if somehting in the trunk is moving around. I have already emptied out the trunk, made sure the spare tire is tightly secured and the noise still exists.
Lastly, I've been parking the car in the same spot in the drive way but last night, the bottom of the car it the ground. There is what I can best describe as road bumps on the way to the parking space. I've not done anything unusal but shortly right after the front tires went over the bump, I felt the bottom of the car landing on the road bump.
Can all these symptoms be caused by the initial jerking motion? Is there something I should do, not do or look for before next Tuesday(dealer appointment).
Thank you in advance,
Nedor
Nedor
