how is the stock LSD in your opinion?
Old Dec 18, 2005 | 10:01 PM
gh0st's Avatar
anyone else feel the stock LSD is a bit inconsistent? kinda hard to explain what im feeling when i push the car hard. its almost like the inside wheel is spinning more tehn it should. other times it vibrates a lot and sometimes even jerks the car.
denward
Old Dec 18, 2005 | 10:32 PM
ZoomZoomH's Avatar
Mulligan User
not sure what you mean, when i drive on the track the LSD really does its job to keep the power down on both rear wheels when coming out of a tight turn
Old Dec 18, 2005 | 10:51 PM
zero LSD issues here, the only time I've experienced inside wheelspin was when a front swaybar malfunctioned and testing alignment settings, improper alignment might be to blame; too much rear camber can cause contact patch issues, and of course I'm assuming the traction control is turned off
and of course it is a Torsen; lifting the inside rear wheel will cause it to act like an open diff, so too much rear shock rebound or front roll pitch can create the situation as well, but unless you have serious power mods there's likely nothing wrong with the LSD itself, Speedsource uses the OE factory LSD on their GrandAm cars without issue
Old Dec 19, 2005 | 06:11 AM
John V's Avatar
Not ******
Haven't had wheelspin issues except in one corner at Peru which was particularly grippy, and that was with the stock front bar. I haven't felt anything since then with the "mystery" bar.
Old Dec 19, 2005 | 09:26 AM
ZoomZoomH's Avatar
Mulligan User
wait, our lsd is a torsen? sweet
Old Dec 19, 2005 | 12:30 PM
gh0st's Avatar
traction control is always off.
im replacing the fluids today. not too sure that it will make a diference though. it feels like there is a mechanical error causing it to lurch side to side when making hard rights.
denward
Old Dec 25, 2005 | 12:26 AM
CERAMICSEAL's Avatar
Actually it's not. It's a Tochigi Fuji unit. Torsen is a registered name and that's why Mazda doesn't refer to their new (Cheaper) diffs as torsens but rather torque sensing which is where the name torsen was originally derived. It's a completely different principal, doesn't have any of the worm gears that the torsen has.
Old Dec 26, 2005 | 05:29 PM
olddragger's Avatar
ghost i have had the same thing but only in a sweeping right turn under hard accleration (if there is such a thing ---JK). None in sharp turns, none in left hander's .I have felt that in some other cars also. It is almost like a "wind up and release" sensation. Causes the rear end to lurch around some. Funny thing is, mine went away after I put my koni's and tein h's on. I have the rb's also. That doesnt make sense to me but it did. And I am running royal purple in the diff
olddragger
Old Dec 27, 2005 | 09:59 AM
you're now not rolling over as far, why wouldn't that make sense?
and my bad on calling it a Torsen, I knew it was the same as the Miata which had the Torsen for years, they both have the Tochigi Fuji LSD now, thanks for the correction
Old Dec 27, 2005 | 08:31 PM
olddragger's Avatar
because the "lurching " around was a sensation from the diff. sort of like when you drive a fixed axle car on the pavement and try to take a sharp curve. like the diff wasnt letting go. I wouldnt think the stiffer suspension would have anything to do with that. But the fact is --it doesnt do that anymore.
olddragger
Old Dec 27, 2005 | 10:23 PM
gh0st's Avatar
olddragger nailed the feel of it right on the button.
i have vogtland springs and koni shocks and im still getting it.
denward
Old Dec 28, 2005 | 06:15 AM
zevans's Avatar
I think I know the sensation you mean, and I think it's actually shunt because we have road-tuned suspension. The diff seems tighter than the rest of the rear of the car, if you know what I mean - bet it would all go away with a brace and some poly bushes.
Particularly noticeable when you play with the throttle with some lock on...
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
