View Full Version : Gas
zaglo6204
12-13-2005, 08:47 PM
hey guys.
today i ventured to the pump (favorite BP station), & i started pumpin 93. i was on empty, so i expected it to take a couple minutes, when all the sudden the pump stopped, as if my tank was full....but i had only put about 3.5 or so gallons in. I was confused, & i tried to keep pumpin, but it would just keep stoppin, so i gave up. the ca drove fine before, & as far as i can tell, its drivin fine now, so im not too worried about. i hope it was just the pump, but could there be a bigger problem behind it??? :cussing: :dunno:
BRealistic
12-13-2005, 08:52 PM
The pump's cut off pressure was probably set too low. Nothing to worry about.
Gomez
12-13-2005, 08:54 PM
Yes, your fuel tank is plastic. It could have melted at the top and reduced your tank capacity. Has happened before.
Have you revved the car FOR AN EXTENDED PERIOD while it was stationary recently?
Otherwise, you may have a gauge or sender problem.......which is more likely.
Gomez
12-13-2005, 08:55 PM
Nah, it's not that. He said 3.5 gallons from empty to full.
zaglo6204
12-13-2005, 09:09 PM
i really havent driven the car hard at all........& i definitely dont rev it while stationary, at least not in neutral....
so hopefully its just a gauge or sender problem, as u said, but better yet, maybe it was just a goofy pump. thanks though....im gonna have the dealer check it out tomorrow, cuz ive gotta go over there anyway. i appreciate it gomez.
Go48
12-14-2005, 06:32 AM
Two possibilities IMO: The nozzle shutoff sensor is not set correctly--had that happen before. Try another gas pump. Or, the rollover flapper in the filler tube is stuck partly closed and bouncing the gas back into the nozzle shutoff sensor. (The flapper I refer to is not the one you can see when looking down into the filler tube. It's lower in the tube and is intended to stop the gas from flowing out in the event of a rollover.)
blue flash
12-14-2005, 07:42 AM
sometimes if you have the gas nozzle angeled too far up it will do this. try to let it hang down naturaly. this happens in my wifes suv alot.
scremn8
12-14-2005, 02:00 PM
the gas tank is suppose to be 15.9 gal. how many of you have been able to achieve that from empty. not me, i can only get 14 gal before it cuts off. then i have to pump very slow to get about another gal. into it maybe. i say say design problem. try it some time and you'll see...
Go48
12-14-2005, 02:14 PM
I assume you mean that you ran the car until it quit because the tank was empty? If so, that doesn't necessarily mean the the tank capacity is not 15.9 gallons. It could mean that the pickup point are not low enough to suck up all the fuel in the tank. That would be my guess. Also, note that the owners manual refers to these capacities as "Approximate Quantities".
scremn8
12-14-2005, 04:53 PM
if that is the case then i would say there is still a design flaw. if i were to run out of gas and still had almost two gal's of gas left, thats not being picked up. i would say that is way too much to fall into the "approximate" catagory. the design of the gas inlet just will not let you fill up to where it should be, and this does not mean topping off either...
Go48
12-14-2005, 05:28 PM
...i can only get 14 gal before it cuts off. then i have to pump very slow to get about another gal. into it...
That's 15 gallons. So less than a gallon was left in the tank. You're exaggerating and making something out of nothing. Get a life!
zaglo6204
12-14-2005, 11:18 PM
guys, i pumped gas fine today. i usually get gas fairly soon after the warning light comes on, & filling takes about 12.5 gallons even with that extra few handle squeezes, so i think mazda was a bit conservative with the early 'low fuel' light, which is fine IMO. when i filled before, the gauge in the car was still accurate, i just couldnt get the damn thing to pump. i believe that, as BRealistic & Go48 said, the pressure cuttoff was low, or the fuel cutoff flap mechanism in the car was the problem. thanks guys.
Go48
12-15-2005, 06:18 AM
Glad to help. Like I said, I've had a similar problem with nozzles on several occasions.
scremn8
12-15-2005, 09:22 AM
what is this get a life stuff i posted something that has happened to me. and you get offended talk about get alife.. also i stated a posiible design flaw. seems to me all want to do is discount other people and take glory for yourself. well its all yours i'm out of this thread
zaglo6204
12-15-2005, 03:42 PM
calm down boys.....ur makin me feel like i started this nonsense, & i dont think thats fair. BE NICE, or else. its the holiday season, we r all 8 enthusiasts.
Go48
12-15-2005, 03:55 PM
"...or else.". Interesting!
zaglo6204
12-15-2005, 08:21 PM
yeah......i know where you live.......
watch it!
ha...ha...ha...
zaglo6204
12-15-2005, 08:22 PM
actually, even better:
SANTY CLAUS IS GUNNA PUT U 2 ON HIS NAUGHTY LIST, & ALL YER GUNNA GIT IS COAL!!!!!!!!
