View Full Version : Greddy Turbo 8 at dragstrip
adrian-1 12-12-2005, 07:49 AM I went to San Antonio Raceway this weekend to see what I was running now with the Greddy turbo/Interceptor X installed.
Got a 13.65sec at 103.54mph.
Dragstrip video (click here) (http://videos.streetfire.net/player.aspx?fileid=F2437843-9B96-4EA2-B19B-4BD60C79FB22)
My reaction time was pretty bad (1.3sec). I was trying to concentrate on my rpms during launch and didn't really look at the tree. My previous best was 13.9 at 98.3mph (6psi/3psi holding). Notice the 5mph higher trap speed than before. You can compare the 2 runs here. (http://www.dragtimes.com/Mazda--RX-8-Drag-Racing.html)
I couldn't get traction in 1st with the boost set at 10psi, so I used the stock 6-7psi to launch and then switched the E-01 to "overtake boost" which is set to 10psi for the rest of the gears. But, since the boost drops off at high rpms, I'd only be at 9 or 8psi for a second then drop down to 7psi. (See E-01 screenshot, boost peaks for a bit then drops, AFR's is the bottom line.) AFR's were around 11.5-12.0 for WOT. No problems detonating or backfiring.
A few members have had success keeping the boost a few psi higher at high rpms using the rpm offset feature on the E-01. I'll be hooking the RPM wire to it next and experimenting with that.
I'm also planning on getting the turboxs exhaust system later to see if that helps with backpressure/exhaust flow. HP gains look to be better than the rest, plus 3in piping and dual mufflers instead of 1 like my current borla.
If the high rpm boost and new exhaust don't break into the 12's, I may look into PTP's turbo.
The Cobra next to me is my roommate. The 12.3sec run was his best time yet and he's on street tires! Mods include smaller pulley, x-pipe, and intake. That thing is a beast.
Autox'ing starts in Feb, should be more fun since that's what this car was built for.
Moostafa29 12-12-2005, 08:03 AM It actually sounds like you did significantly better. 5mph high trap, with shitty launch and traction, and you still pulled off 0.3 on your times. Once you nail the launch, get better traction, suspension set up or tires, you should be in the low 13s. Great job Adrian!
cas2themoe 12-12-2005, 09:04 AM Very good indeed! Low 13's will come soon. Thanks for sharing.
dmorales 12-12-2005, 09:06 AM Great Job! Wish I could do a 13.6! :(
________
Recall nexium (http://www.classactionsettlements.org/lawsuit/nexium/)
adrian-1 12-12-2005, 12:33 PM I just posted my dyno runs from today in this thread (http://www.rx8club.com/showthread.php?p=1155836#post1155836). Also got it on video. ENJOY.
I doubt I can stiffen the suspension anymore. I already have MS springs/shock, sway bars, strut bars.
I'm using Falken RT-615's which are nice autox'ing tires. The only ones better would be slicks, which I won't be getting.
XDEEDUBBX 12-12-2005, 12:47 PM good shyt adrian, your dragger is coming along!!
TxRx8 12-12-2005, 01:26 PM Nice Depeche in the background there... :)
adrian-1 12-12-2005, 01:48 PM Yup, saw them in concert in San Antonio last month. Show was great, plus had floor seats!
That 60-ft time is what's keeping you away from the 12s. :) Any worries about the car's rear-end, or axles?
IZoomZoomI 12-12-2005, 04:16 PM Some decent numbers finally! Great job. Was that your only race? If not what were your other times?
RotaryManiac 12-12-2005, 04:46 PM nice. Good luck breaking into the 12's, although i do think not reving to 9k with the rx8 sucks.
adrian-1 12-12-2005, 05:41 PM That 60-ft time is what's keeping you away from the 12s. :) Any worries about the car's rear-end, or axles?
Yup, I'd like to get below 2.0 60ft times (like the cobra).
I didn't have any problems with 2nd gear since I was careful(probably could have shifted faster into 2nd). Although I did have some grinding issues going into 4th. Not really jamming, just not going in smoothly.
A rebuilt transmission may be one of my mods next year.
I did 4 runs, 1st was 13.9 due to 10psi launch and spinning. Others were 13.7's due to a bogging down launch. Wanted to do another run, but there was a camaro with nitrous that blew his engine. Looked like the cleanup was going to be awhile so we left. All trap speeds were 102-103mph.
BigOLundh 12-12-2005, 07:13 PM Looking good adrian.
Sapphonica 12-12-2005, 08:51 PM Have you/will you try launching in 2nd?
I know its major clutch abuse, but you lose time on the 1-2 shift and 1st is just about useless with the turbo.
Once I get my 8 tuned, I might go for a numerically lower rear axle ratio for that reason & to get better freeway gas mileage.
Moostafa29 12-12-2005, 08:55 PM I'm using Falken RT-615's which are nice autox'ing tires. The only ones better would be slicks, which I won't be getting.
Those are your 17in tires/wheels right? What is the width? Do you think it would be better with your other wheels, now that you have much more power, and need added traction?
Why say NO to the slicks? just wondering, is it the price?
IZoomZoomI 12-13-2005, 03:26 AM Those are your 17in tires/wheels right? What is the width? Do you think it would be better with your other wheels, now that you have much more power, and need added traction?
I think he mentioned when he got it he was running a 245 width and the wheel is 17x8.0. If he went 8.5 he could have fitted some wider 255 width tires.
adrian-1 12-13-2005, 06:27 AM Have you/will you try launching in 2nd?
No, I have never tried. I believe it'll only benefit very high hp cars. I'll experiment next time.
17x8's with 245/45's. The other tires are 275/30/19's on a 19x9.5 rim, but they weigh alot more.
Yes. I also want my setup to be legal on the street.
adrian-1 12-13-2005, 06:32 AM I think he mentioned when he got it he was running a 245 width and the wheel is 17x8.0. If he went 8.5 he could have fitted some wider 255 width tires.
I checked tirerack and they have some SSR comps in 17x9.5 that weigh 15.9lbs, but cost $430 each. I'll look around for a used pair.
rx8wannahave 12-13-2005, 08:15 AM adrian-1....great job, it's been great watching you improve your car and times...wow, 13.6 and according to you all (since I've never been to a track) there is alot of room for improvement.
Wow...thanks for sharing, I'll have to watch the vid at home (I can't wait) but 13.6 without a good take off...wow...just wow. Thanks...good job!
Now...to figure out (for me) how to get into the 13's...NA....hmmmmmm...lol
:score:
Nevermind how brutal Slicks can be on drive-components. Stay away from that much traction until you are sure the axles can handle it.
:D
IZoomZoomI 12-13-2005, 03:14 PM I checked tirerack and they have some SSR comps in 17x9.5 that weigh 15.9lbs, but cost $430 each. I'll look around for a used pair.
the price we pay to save a few pounds hehe.
