New Brake Rotors?
Old Dec 9, 2005 | 06:39 PM
kachud's Avatar
Mad Scientist
Red face New Brake Rotors and Studs?
I am going to replace all for rotors on my 8. I have had 6 studs break in the last 6 months. I don't know if it was because my auto body shop overtightened them, which they did. Or if this is a manufacturers defect. I think it is a combination of the two. The 8's studs are really soft. Anyway instead of fixing the studs again and again I think I will buy new rotors with after market studs. My question is, what do you recommend the best after market rotors are? I like Brembo but I don't want to drop 4 grand on a new brake system. I just want replacement rotors. Any help would be appreciated.
Old Dec 9, 2005 | 09:31 PM
Rotors have nothing to do with the studs except the studs hold the rotors and wheels to the hubs. You may want to replace the studs.......
Old Dec 11, 2005 | 03:43 PM
kachud's Avatar
Mad Scientist
The studs are pressed in the rotors and it would cost a lot in labor to press them out. I would be better off investing in new rotors and save that much labor.
Old Dec 11, 2005 | 04:26 PM
Studs are pressed into the hubs.....rear rotors are not even bolted in.....remove the calipers...and they slide right off. Front ones are held on by 2 keeper screws....more to hold the assembly together at the factory than anything else.
So....new hubs....or replace the studs I know which I'd pick
( check out the prices of the hubs...I think you'll change your mind! )
Old Dec 11, 2005 | 04:30 PM
get rid of the OE lugnuts and lock as they are the problem, replace with quality aftermarket, light coat of anti-sieze on the stud thread, drop the lugnut torque back to 100 lb-ft to account for the lubed studs, problem solved
Old Dec 11, 2005 | 05:20 PM
kachud's Avatar
Mad Scientist
What is the size of the studs in our 8's?
Old Dec 11, 2005 | 09:23 PM
M12 x 1.5 threads
Old Dec 12, 2005 | 06:02 PM
kachud's Avatar
Mad Scientist
thanks
hufflepuff
May 30, 2016 10:45 AM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
D13
Oct 1, 2015 07:55 AM
