What octane gas do you use ?
Old Dec 8, 2005 | 04:05 PM
Stick-it's Avatar
Looking into buying my first RX8. I owned an RX7 when they first came out in '79.
I have read the 8 uses regular unleaded ? Is this what most of you use ?
Any pinging with the 87 octane ?
Thanks.
Old Dec 8, 2005 | 04:08 PM
ZoomZoomH's Avatar
Mulligan User
the RENESIS has 10:1 compression, the owner's manual RECOMMENDS using premium for best performance, and that is what I use
the 8 CAN use 87 if necessary, the ECU will delay timing to prevent detonation, but it will result in reduced performance.
Old Dec 8, 2005 | 04:10 PM
Tigster's Avatar
RX8 ADDICTED!!!
I use 93, I figure whats a couple of bucks at the pump anyways?
fray's Avatar
The book says:
Your Mazda will perform best with fuel listed in the table:
Premium unleaded fuel --- 91 [(R+M)/2 method] or above (96 RON or above)
You may use a regular unleaded fuel with Octane Rating from 87 to 90 (91 to 95 RON) but this will slightly reduce performance.
Fuel with a rating lower then 87 octane (91 RON) could cause the emissions control system to lose effectiveness. It could also cause engine knocking and serious engine damage.
(Goes on to say you can use up to 10% ethanol)
Old Dec 8, 2005 | 04:15 PM
NgoRX8's Avatar
I use 91 all the time. Just because I want every ounce of performance I can get.
Old Dec 8, 2005 | 05:57 PM
YT1300's Avatar
Turning and burning
The pumps says 92 whenever I fill it.
Old Dec 8, 2005 | 06:40 PM
Armaant's Avatar
Armaan
i've been usuing 89 not because of price but because i thought thats what everyone else was using...my car got 205whp at the dyno with that gas and i'm getting the cz tuned on the 20th...any suggestions? Should i switch to 93 octane?
Old Dec 8, 2005 | 08:26 PM
ZoomZoomH's Avatar
Mulligan User
why not, you may make *more* power with premium, worth a try
Old Dec 8, 2005 | 08:42 PM
Armaant's Avatar
Armaan
^^yea im saying theres no way it could actually decrease performance or anything right(sounds like a stupid question) but i mean the readjustment of the ecu and cz to a different octane and the temp conditions?
Old Dec 8, 2005 | 08:48 PM
ZoomZoomH's Avatar
Mulligan User
so? let it adjust and see what happens, that's why you put it on the dyno in the first place, to see how the car responds to different settings right?
Old Dec 9, 2005 | 04:15 PM
Armaant's Avatar
Armaan
yea but i dont want to pay to have it dyno'd and tuned then have to get it retuned later...whatever i'm switching to higher octane gas
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Zube6115
Sep 30, 2015 12:57 PM
