DropTheHammer
11-30-2005, 12:43 AM
can some one please tel lme how 2 shut thi sthing off soon as i get in my car and drive i have a voice telllin me 2 turn ever 2 sconde.
View Full Version : navi DropTheHammer 11-30-2005, 12:43 AM can some one please tel lme how 2 shut thi sthing off soon as i get in my car and drive i have a voice telllin me 2 turn ever 2 sconde. RX-8 8-XЯ 11-30-2005, 01:20 AM I had the same problem, the only way I could get it to stop was to complete the trip... might be easier if you are done at work and set the destination as home (assuming this is where you are going). Unfortunately I don't think there is a way to terminate the trip Rx7Roadster 11-30-2005, 08:30 AM Press ok and a menu will pop up. Select delet destination or something like that. I think it is the last one on the menu. blue flash 11-30-2005, 08:53 AM Press ok and a menu will pop up. Select delet destination or something like that. I think it is the last one on the menu. correct press the menu buttom then at the bottom of the screen it will show delete destination.it drove me nuts until i found this option iKenndac 11-30-2005, 10:10 AM On mine the bottom option is "Turn Off Guidance". Same thing, different words. DropTheHammer 12-02-2005, 11:50 PM there is a god thank you guys Jaguar_MBA 12-03-2005, 08:14 AM Press the center button down when the map is up......once that is done, you will get a list of options, vertical stacked on top of the map. Select "Delete Destination" |
