Hesitation, strange noise @ 7Krpm, flashing CEL
Old Nov 28, 2005 | 01:43 PM
Section 8's Avatar
having a strange issue with the car. When I hit 7K and rising through 8K, the engine hesitates and makes a strange throbbing noise, power is reduced and the CEL flashes until i dip below 7K.
Anyone experience this before? I found a few threads with similar symptoms, but not quite the same. The CEL does not stay lit after i drop revs below 7K.
Old Nov 28, 2005 | 01:46 PM
zoom44's Avatar
misfire
Old Nov 28, 2005 | 01:49 PM
rkostolni's Avatar
Or detonation. Pull your plugs, look for signs of fouling or detonation.
Old Nov 28, 2005 | 01:51 PM
Section 8's Avatar
should i be getting fouling and detonation with 1100 miles on the car? I'm not sure what flash the PCM is at either haven't even made the first payment yet.
Old Nov 28, 2005 | 02:05 PM
rkostolni's Avatar
If the dealer flooded or near flooded your car before you picked it up, your plugs could be partially fouled from that causing a mis.
Old Nov 28, 2005 | 02:09 PM
Section 8's Avatar
Hmmm..interesting. I had the CEL come on solid 2 weeks ago, and when the wife took it in they said "you flooded it" but I think i would have known if I had flooded the car.
Guess I'll call them and demand new plugs then and see if they'll pony up. I'll also try to get the latest PCM flash put on there, what's current, R?
Old Nov 28, 2005 | 02:18 PM
Nemesis8's Avatar
Bigus Rotus
It should already be on R if the dealer did the recall work.
Old Nov 28, 2005 | 02:28 PM
snizzle's Avatar
Shakezula, the Mic Rula
IF
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
