Down shift grind
Old Nov 27, 2005 | 07:10 PM
kw1k's Avatar
Down shift grind
Alright guys, problem is that in HIGH RPM's when i want to down shift from 3rd to 2nd gear I get a grind Now this is somethign that just started with my 8.
I searched and found out that I should Check/ change my tranny fluid ( which is a good idea because i bought the car w/ 23k miles on it even though its from the dealer you can never be to sure ) 2nd i found this Stainless steel clutch hose from RP , Basicly it talks about the problem i'm having right now, and that it takes care of the problem.
but when i do a slow down shift from 3rd to 2nd i sometimes grind but if i do a quick down shift i get a solid grind , This problem HAS to be fixed because i'm going to start tracking my car and down shifts are a MUST and i can not have this BS
If these two things dont work. I'm going to call the dealer and have them check it out..
So my friends, any other tips / ideas you might have on this subject
Old Nov 27, 2005 | 07:39 PM
QBallz's Avatar
Sound like it maybe a bad syncro. Try double clutching and see if it still grinds. Also a good synthetic would probably help, but it's a bandaid if stuff is starting to grind already.
Old Nov 27, 2005 | 08:05 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
Got a clutch line from mazdatrix for 20 bucks-best money ever spent-also running Redline MTL 90. Not a problem with the tranny. Are you atleast attemping to rev match I hope? Not trying to be sound rude, but just checking the basics first
Old Nov 27, 2005 | 08:39 PM
grapes's Avatar
Yeah try the redline first in both trans. and diff. Should work, otherwise theres a problem. Just a question but what RPM's are you downshifting at.
Old Nov 28, 2005 | 07:06 AM
kw1k's Avatar
Yes i am.
Old Nov 28, 2005 | 07:08 AM
kw1k's Avatar
Well after i finish 3rd before i hit 4th, I hit the breaks let the RPMS drop a bit and down shift
Old Nov 29, 2005 | 12:05 AM
YT1300's Avatar
Turning and burning
Why not just let the engine spin up a bit; it sounds like you're grinding because the syncro is being hurried.
Old Dec 11, 2005 | 05:42 PM
Bart!'s Avatar
RAWR!@#
Syncro.
Old Dec 11, 2005 | 05:59 PM
gonnahanvan8's Avatar
Wouldn't that be a warranty issue?
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
