RX 8 mods
Old Nov 16, 2005 | 01:49 PM
OliGeorgs's Avatar
RX 8 mods
Hello I´m new to the rotary world, always had V8´s. What can you tell me about moding the RX 8 for performance. Thanks.
Old Nov 16, 2005 | 01:54 PM
kw1k's Avatar
intake,exhuast,ecu,flyhweel, 4.77 gears 75 shot nitrous
Old Nov 16, 2005 | 01:57 PM
expo1's Avatar
He's as bad as Can
I can tell you that it's not easy and it’s not cheap to increase the performance of this car. Hard as some new owners find it to believe Mazda did a good job on this car, there isn’t much hidden HP. This sub-forum contains most if the information you seek.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/
The search feature will also help. Just type in a MOD you have in mind and there should be a thread on it.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-how-use-search-function-rx8club-com-forum-73846/
Old Nov 16, 2005 | 02:04 PM
KYLiquid's Avatar
Oil Injection
if you want power, go with the greddy turbo kit and the x-interceptor ECU, it will set you back about 5-6K with the install and tuning, but it will be a nice kick in the pants, thats really the only option the rx8 has now for big power.
If you didnt want to go turbo, you could spend almost as much on intake,header, exhaust,ecu/piggy back, flywheel, rear gears, mid-pipe, exhaust and only get about 20-30hp.
Thats talking power, the real shining point of this car is the handling, that can be upgraded a bit, biggest thing, get better tires than the OEM dunlop/bridgestone. That will make a big differnence. Then you can mod the suspension parts and really making this cars handling world class.
Old Nov 16, 2005 | 02:09 PM
DreRX8's Avatar
Several superchargers are coming soon as well--but the best mod for more power is one of the turbo kits on the market. If you just want a little more--intake/exhaust/ecu tuning are about the best--but you'll end up spending about $2000 for about 30HP that route which will equal a car that is about as quick as a 350Z to 60. Turboed 8s are good for low 5 second 0-60 passes consistently.
Old Nov 16, 2005 | 03:12 PM
Jaguar_MBA's Avatar
You will need to read everything on this website:
http://www.racingbeat.com/FRmazda4.htm
It will tell you what to truely expect from some mods. Don't trust the SR Motorsports HP claims.
Old Nov 16, 2005 | 05:37 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
I might also suggest learning a little history about rotary engines to give you some backround if you don't already know how they work. The RX7 Club is good for this, too.
www.rx7club.com
Old Nov 16, 2005 | 08:36 PM
Low Fly'n 8's Avatar
This car likes curves much more than 1/4 mile straights.
gwailo
May 14, 2024 06:57 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Brokegang
Jan 3, 2016 12:45 PM
FubarI33t
Sep 28, 2015 08:45 PM
