Starting it up...
Old Nov 16, 2005 | 07:13 AM
Transam kid 01's Avatar
The anti-ricer
Starting it up...
So i've been told by everyone including the dealer to wait three minutes for the car to warm up before i drive it, but what if there is an emergency....is there a way to avoid the waiting period in this rare occasion? if so...are there any side effects?
Thanks guys,
Sean
Old Nov 16, 2005 | 07:19 AM
Asmoran's Avatar
Just don't rev the engine over 4K until it's warmed up and you'll be fine.
Old Nov 16, 2005 | 07:33 AM
expo1's Avatar
He's as bad as Can
You need to find new people to take about your car with.
Just like Asmoran said don't beat on a cold engine, keep the rpm's under 4,000 till warm. I have been doing that for over 50,000 miles.
Old Nov 16, 2005 | 07:36 AM
czr's Avatar
czr
RX8 RX8!
I agree. And this goes for any car! I don't think there will be any immediate harm but long-term can't be good.
Old Nov 16, 2005 | 08:21 AM
Glyphon's Avatar
脾臓が痛みました
best thing to do is start the car up and drive off immeditately, although in extremely cold weather (ie, -20) then you might need to let it warm up. this is also the fastest way to warm up the engine safely. like was mentioned, don't rev it over 4k (i try not to go over 3k) until it is completely warmed up. doing this will also positively effect your gas mileage.
Old Nov 16, 2005 | 08:34 AM
The anti-ricer
o wow....ddnt kno that...thanks guys!..and i think i should have a talk with that dealer
Old Nov 16, 2005 | 08:39 AM
expo1's Avatar
He's as bad as Can
Doing that is just a waste of time, they don't care.
Old Nov 16, 2005 | 08:55 AM
The anti-ricer
lol at the pic....just to double check now...i only need to wait the 3 minutes after driving if i bring it above 5k frequently that drive?
Old Nov 16, 2005 | 09:04 AM
expo1's Avatar
He's as bad as Can
Think of it as an athlete, does a running back roll out of bed and run the 100-yard dash? No an athlete warms up before doing any hard work. In the case of your 8 keep the RPM’s under 4,000 until the temp needle is in the middle then ZOOM ZOOM. That will take less than 5 minutes and under normal driving you don’t need to rev over 4,000.
Old Nov 16, 2005 | 09:12 AM
The anti-ricer
Thanks for the clarification guys
Old Nov 16, 2005 | 09:15 AM
Asmoran's Avatar
You're thinking about it the wrong way. Don't think "how long do I have to wait before driving". Instead think "Is the temp gauge in the middle yet". If so, have fun. If not, take it easy for a few more minutes.
Old Nov 16, 2005 | 09:41 AM
Nubo's Avatar
Lubricious
I'd recommend waiting about 5 minutes *after* the temp gage settles. Coolant temp maxes at around 180 degrees. There are parts of the engine that will get hotter than that. This is one reason why real oil-pressure gauges are useful -- you can judge when the engine has reached normal temps by the change in oil pressure. Since the 8 doesn't have an actual oil pressure gauge, 5 minutes after coolant temps stabilize is a good rule of thumb.
Old Nov 16, 2005 | 10:43 AM
KYLiquid's Avatar
Oil Injection
I like to warm up the car a bit before driving it, but not anything like 3 mins....thats just wasting gas/time.
When I need to leave for work or whatever and the car has been sitting a while (cooled down) I always get in the car and start it first thing, so its on and running, then I close my door, put on my seat belt, double check ive got everything i need, phone, wallet, ect. Put on the radio and tune in something good or put on a CD, roll my windows down if its nice out, ect....by the time ive done everything, the car has been running for 30 secs or so, and I drive off, taking it very easy the first few mins/miles, low revs, smooth power, no heavy throtle, ect. then after the eng temp is up to normal I slowly expand the revs over the next couple mins, take a gear to 4k, then the next gear to 5k, then a gear to 7k, ect. Then Im ready to use the full rev range and drive how I want.
The time it takes me to go from a cold start to using WOT and full revs, about 10, 15 mins, so its really nothing.
Old Nov 16, 2005 | 12:21 PM
Mikelikes2drive's Avatar
unless!!! ur car isnt broken in yet...
i think u should actually wait for ur car to warm up if your car is still new before u drive it off...
but usually i just let the idle settle and then take off at low rpms
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Dokuji
Nov 1, 2016 02:51 PM
wanted797
Aug 26, 2015 11:24 PM
harithac
Aug 26, 2015 09:24 AM
poppinparker
Aug 10, 2015 09:20 AM
