Quick way to change oil filter???
Old Nov 14, 2005 | 07:43 PM
Wankel1's Avatar
RX8 Daily Driver
Sup everyone, i was just curious how to pget in for the kill and swap the filter out for my dad, he's out of town and expects me to have it done by tomorrow but it's kind of annoying. All help would be greatly appreciated.
Thanks, Danny
Old Nov 14, 2005 | 07:47 PM
Take out the dipstick...use left hand and unscrew the filter...put a rag between the filter and block to catch the oil that will drip out.....remove filter.
Use a bit of oil to lube the filter seal.....tighten it until it touches....and the 3/4 turn more.
Drain oil, and refill....ten minutes tops
Old Nov 14, 2005 | 07:53 PM
Wankel1's Avatar
RX8 Daily Driver
Yea but it was uncomfy for me i thought if you possibly got under it it could be easier but from above i just don't feel good. I've done plenty of oil changes =] but just another reason why IMO hondas are easier to work on, of course im a juvenile, naive, etc. 17 year old student :D.
Old Nov 14, 2005 | 08:33 PM
army_rx8's Avatar
X-Sapper
hah ano way you can get it from below...if you are changing the oil and filter...there won't be much of anythign driping out of the filter.....if not yes use a rag to catch it.
but only way to get at it is to reach around and twist
Old Nov 14, 2005 | 08:36 PM
StealthTL's Avatar
Metatron
Exclamation First change?.....
Is this the first oil/filter change?
The factory uses large sumo wrestlers to tighten the filter - if it hasn't been changed already, I would say a teenage novice has NO chance at getting it off.
Seriously, you won't be able to do it - maybe take it to Mr. Lube or someone who knows the trick of breaking a stuck filter free, because all you will do is damage it, making it undrivable.
"Hear me now, und believe me later!"
- Hans und Franz.
S
Old Nov 15, 2005 | 01:44 AM
mazdaspeedtech's Avatar
Mazda CertifiedTechnician
HAHA yeah, you need filter pliers, our dealership has special pliers that we use on those annoying first oil changes. But yeah, as the other person said, take out the dip stick, and go underneath the hoses there. I wouldn't take it to "Goober Lube", its worth the extra couple of bucks to take it to the dealership. I think that our LOF is $27.99. (Castrol GTX Oil)
Old Nov 15, 2005 | 08:55 AM
ucfracerx8's Avatar
Pistons are Over Rated
Go get a 65/67 two step fliter wrench from Advance, Napa or equivalent, the metal kind that fits over the end of the filter, a 12" extension and at least a 24" wrench to get enough torque to get the thing loose. I did notice that I had to sort of jam and beat the wrench onto the filter supplied with the car, it had a slightly larger diameter than the replacements I got from Trussville. The filters are on tight, but they will come off, just be careful and take your time. It will drip a little, but the rag will catch it all, the drain plug is easy. I have quite a long reach and was able to get it off and drain the oil without jacking the car up. Once the filter is off, follow the other recommendations and you will be all done in about 15 minutes. I am amazed how quickly you can change the oil in this car, now if the wife's Tribute would just have the filter in a better place so that I didn't have to clean the downpipe everytime, and a plug that was not buried in the back behind everything I could do both vehicles in 1/2 hour.
Old Nov 15, 2005 | 10:58 AM
staticlag's Avatar
The Professor
^ Your going to need a 3/4 inch flex joint also.
Old Nov 15, 2005 | 11:21 AM
ZoomZoomH's Avatar
Mulligan User
^concurs on the flex joint
65mm/14 sides filter cap wrench + flex joint + 12" extension + nice socket wrench = *very* easy filter removal
Old Nov 15, 2005 | 01:38 PM
JonsToy's Avatar
Registered Rep
Once you find the filter will turn, poke a small hole in the top of the filter. This will help the oil drain out from the filter.
Old Nov 15, 2005 | 01:50 PM
xrider01's Avatar
127.0.0.1
are you supposed to remove the filter first and then drain the oil? i've always drained the oil first and then removed the filter.
Old Nov 15, 2005 | 01:57 PM
NgoRX8's Avatar
I drain the oil and then remove the filter. Actually, as long as you do both before turning your car back on you'll be fine. All I use to take off the oil filter is a twist of the wrist. Takes a while though.
I think I know what you are saying Danny. The position to get to the oil filter is hard. I have an 04 and a buddy of mine has an 05. Theres a clear difference in room and I can get to my filter rather easily. When I tried doing his there are just things in the way making me have to twist around. You'll get use to it.
Old Nov 15, 2005 | 02:17 PM
guy321's Avatar
Humpin legs and takin nam
i use a 12" long ratchet extension with the mazda filter wrench adapter.
Old Nov 15, 2005 | 02:54 PM
whenson417's Avatar
just loosen up the air condition line from the fire wall so you can have a little more room to squeeze you arm through. i have fairly large arms and couldn't get a good grip on the filter to turn it until I unhooked that line. it was a piece of cake after that.
Old Nov 15, 2005 | 07:13 PM
NONONO just take out the dipstick and then reach under there and MANHANDLE the thing. Don't go disconnecting all this other BS, the oil change pays .3hrs for a reason, it shouldnt take you longer than 18 minutes to perform.
Old Nov 15, 2005 | 07:22 PM
...I wear XL gloves...so I don't have small hands by any means.........just take out the dipstick and turn the filter counter clockwise to get it out...just watch your knuckles...I always seem to rough them up on something if I forget to wear gloves
Old Nov 15, 2005 | 08:03 PM
xrider01's Avatar
127.0.0.1
takes me about 20min. to have mine changed. i've gotten used to doing the oil change, but i still find it rather difficult at times to put in the jack under my car for me to get under it and remove the oil pan plug.
Old Nov 15, 2005 | 09:15 PM
ZoomZoomH's Avatar
Mulligan User
^get a Fumoto Drain Valve, never have to jack the car up to change oil again
I got one, and i just finished changing oil, no spills/drips at all, and no jacking car up!
but I think there's a small oil pan leak, gonna have to track it down... grrrrr
Old Nov 15, 2005 | 09:19 PM
xrider01's Avatar
127.0.0.1
^^ the 8 is pretty low to the ground. how could you get to the plug to take out all the oil?
Old Nov 15, 2005 | 09:29 PM
ZoomZoomH's Avatar
Mulligan User
because i have this:
www.fumotovalve.com
it replaces the oil pan drain plug, once installed, i just reach right under the car, and flip a switch, and voila, oil gets drained!
Old Nov 16, 2005 | 10:54 AM
FLybOi drE's Avatar
www.fumotovalve.com
seems really useful, but i'd worry that by chance, something might hit it and release the valve and spill all the oil...next thing you know, your engine's a stone
Old Nov 16, 2005 | 11:19 AM
ZoomZoomH's Avatar
Mulligan User
it's highly unlikely, where the drain plug is, that it will get hit by anything that will open it up, unless you take the 8 offroading
mr. GrandGame
Sep 9, 2025 10:41 PM
05TR1CH
Apr 18, 2023 04:56 AM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
Junirol
Sep 22, 2015 06:02 AM
