looking for 2 piece brake rotors.
Old Nov 6, 2005 | 04:53 PM
hondasr4kids's Avatar
I want to replace my stock rotors with 2 piece rotors since I'm having bad experience with the stockers. Does anyone make a set beside Auto Exe?
Old Nov 10, 2005 | 09:36 AM
RotaryZZ's Avatar
You mean floating rotors? Why you need that, do you overheat with the stockers?
I've found the stockers actually pretty good, even in track condition. All I do is to swap in better pads while on track.
Old Nov 10, 2005 | 10:58 PM
AlexCisneros's Avatar
voila
http://forums.racingbrake.com/viewtopic.php?p=147
also...
endless and project µ
Old Nov 10, 2005 | 11:06 PM
Why you need that
and you should see the caliper difference... oh wait
Old Nov 11, 2005 | 01:06 AM
^^^Alex...keep us posted
Old Nov 30, 2005 | 07:26 AM
Talking
ohboyohboyohboy
Racing Brake has the Pre-Order ready
STU guys do like me... Tell the wifey you really really want this for Xmas
Old Nov 30, 2005 | 09:01 AM
Imp's Avatar
Imp
What's next?
Drop around 24lbs of unsprung weight... nice.
Old Nov 30, 2005 | 12:56 PM
crossbow's Avatar
Damn...you guys get all the cool toys.
Old Nov 30, 2005 | 03:24 PM
thanks for the info that weight loss is just the front brakes only but some of that will be offset by the caliper adaptor mounts
Old Nov 30, 2005 | 04:13 PM
Dark8's Avatar
Ride Naked!
Alex - thought you were running 17" wheels. Site says the 13" kit will fit the OEM 18" wheels. Did they say a 17" wheel will work with the big 13" kit? Or do they make a replacement caliper to go with the 12.6" smaller discs.
Old Nov 30, 2005 | 07:01 PM
~)('s Avatar
Hi everyone, I'm new to racing and I'd like to know what benefits these brakes provide. Thanks in advance.
-jc
Old Nov 30, 2005 | 07:41 PM
PedalFaster's Avatar
See AlexCisneros's post above.
Old Nov 30, 2005 | 09:08 PM
I am running the 17s... For me, it would only be the floating rotors and not the large rotors. Now if the calipers fit inside... well then that'd be something. For now I'll have to make do with the weight loss from the smaller rims
Old Nov 30, 2005 | 09:30 PM
how much do your wheels weigh?
Old Nov 30, 2005 | 09:37 PM
crossbow's Avatar
What class does the 8 get bumped to if you run 17's?
Old Nov 30, 2005 | 10:49 PM
SP, STU, or higher
Old Dec 1, 2005 | 01:01 PM
ok, RacingBrakes told me via email that they will be going ahead on a 2-pc rear rotor for the RX-8 with an estimated 9.6lb weight savings. Their drilled & slotted 1-pc performance replacement rear rotor is 1 lb lighter than OE
they are also going to look at a replacement 2-piston aluminum rear caliper too
edit: I'm not in yet, I'm evaluating my financial position, it's a good deal but if you're tight on dough ....
Old Dec 1, 2005 | 02:46 PM
~)('s Avatar
How much is the rear 2-pc rotor going for?
Old Dec 1, 2005 | 02:51 PM
whiterex's Avatar
Pink Means PASS
Originally Posted by TeamRX8
looks like I'm in on the pre-sale
I guess you are going STU for sure...
Old Dec 1, 2005 | 02:57 PM
well yeah, I wouldn't have sold off all my Stock wheels and tires if that weren't the case, of which you were one recipient ...
no word on the rear 2-pc price yet
Old Dec 1, 2005 | 03:59 PM
whiterex's Avatar
Pink Means PASS
Forgive me, I have been staring at my 2 screens all day... the brain is officially fried.
Old Dec 1, 2005 | 05:27 PM
Spin9k's Avatar
Momentum Keeps Me Going
The idea of losing so much weight is inviting, but someone who knows, please help me understand a bit more about these lightweight brakes. First, I get all excited about it then I get stuck on a couple points that seem counter-intuitive.
Ok, bottom line, the point of a brake is to be a heat sink, take the energy of mass at speed into heat and slow the car. Now nice heavy iron calipers and rotors do a good job at that, they sink alot of heat and come back for more. We all know our brakes are awesome, if not lightweight.
BUT... and here is where I begin to worry....take away the mass of iron that's there and the heat generated still has to be absorbed during braking and dissipated as quickly as possible so there is not overheating and fade as a result. These beautiful & nice lightweight calipers aren't going to do that like the original, the somewhat lighter rotors are less effective in that regard as well. And I'm esp concerned at the track, not autocross, but the race track where I have seen my stock brakes get up into the 500 degree heat range.
So in the end, is the braking performance helped or actually hindered by this lightweight replacements? - putting the benefits of less unsprung weight aside for the moment?
Old Dec 1, 2005 | 06:20 PM
clyde's Avatar
www.TeamWTF.org
I think you answered part of your question with that.
Old Dec 1, 2005 | 06:42 PM
A lot of your concerns are with heat dissipation.....the lighter rotors have lower mass...but will probably loose heat faster due to the better venting..and the aluminum hats will dissipate heat faster than the cast iron......
Old Dec 1, 2005 | 06:48 PM
16.2 front and 16.8 rear... Not bad for $200 rims (they're no 15lb SSRs, but then they cost half as much )
According to Tire Rack (via spec sheet) the 225/45/18 RE040 weigh 28lbs and the Kumho MX 275/40/17 weigh 28lbs so no real gain or loss there
