Electrical Problems!
Old Oct 31, 2005 | 01:29 AM
cgseanp's Avatar
my dang car is acting crazy! the other day the horn started honking on its own, my radio presets and my trip odometer zeroized when I turned the car off, when I turn on my high beams my radio turns off for a split second and my car feels like it turns off for a split second! And then tonight when i went to get gas, my car wouldnt turn back on at all! I honked the horn though, and then it fired right up! I think i read that our cars have some electrical problems? Sorry, I dont have time to do a search right now, i just got home from driving 400 miles and I have to work in like 6 hours...
Has anyone had similiar problems? and are electrical problems covered under the factory warranty??
thanks in advance!
Old Oct 31, 2005 | 01:40 AM
staticlag's Avatar
The Professor
Battery terminals loose?
Old Oct 31, 2005 | 06:13 AM
Go48's Avatar
[QUOTE=cgseanp]Has anyone had similiar problems? and are electrical problems covered under the factory warranty??QUOTE]
Something like this would certainly be covered under the warranty. Only problem you might have with that is if the dealer can't duplicate the problem.
Before taking it in to the dealer, check battery connections as static suggests and also check all grounding points to verify that they are bolted down tight.
Old Oct 31, 2005 | 11:10 AM
cgseanp's Avatar
This morning I checked the battery connections, and one of them was loose! It was just barely attached to the battery.. as I was putting it on, my horn started honking at me again.. I am assuming that is why it was honking at me in the first place.
My problems started after i checked my oil, I must have leaned on the battery cover and moved the battery cable. Could a loose battery connection cause my car to turn off for a split second while driving when I hit my high beams?
Thanks for the advice.
Old Oct 31, 2005 | 02:15 PM
Go48's Avatar
Originally Posted by cgseanp
My problems started after i checked my oil, I must have leaned on the battery cover and moved the battery cable. Could a loose battery connection cause my car to turn off for a split second while driving when I hit my high beams? Thanks for the advice.
I doubt whether bumping the battery cover would loosen up a properly tightened battery cable. If the cable was loosely clamped to the battery post and because of that supplying the minimum electrical energy required to operate the basic components in the car and you add a large electrical load like the high beam headlights, I would think it highly possible that the engine would at least stumble if not cut out completely.
Old Oct 31, 2005 | 02:27 PM
cgseanp's Avatar
oh, i think the cable was already loose.. so when i bumped it, it kind of popped off the battery causing all the problems. it scared the **** out of me when i was leaning over to check my oil and my horn honked at me.. and this was all on the side of the freeway because my low oil level light came on while i was driving to tucson.
yurcivicsux
192
Sep 12, 2017 10:54 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Vedivan1
Sep 18, 2015 12:39 PM
