Compustar Remote Starter
Old Oct 29, 2005 | 07:37 PM
jcataldo's Avatar
Has anyone had any experience with Compustar products? Thanks
Old Oct 31, 2005 | 01:37 PM
forbidden's Avatar
Yes, they are my standoff favorite alarm/rs system that I both use personally for the last 6 years now and will recommend to any customer wanting a good reliable unit. The unit itself though is only as good as the installer.
Old Oct 31, 2005 | 02:02 PM
BoosTED's Avatar
Compustar
I bought one before the FCC made them reduce their range. Under perfect conditions mine has a 6,000 foot range.
I guess the new ones have a 4,000 foot range, still can't complain about that.
My uncle has one in his H2, has had it for a couple of years and still loves it.
I have to install one in his 50th Anniversary Corvette (Z06).
Old Oct 31, 2005 | 02:04 PM
BoosTED's Avatar
Thumbs up Compustar
I totally agree, ANY remote start or alarm is only as good as the installer.
Old Oct 31, 2005 | 07:01 PM
whosyourbaba's Avatar
its helps in the winter and warns me if my alarm goes on. it does also not respond at times, but thats rarely. but it happens.
Old Nov 1, 2005 | 05:30 AM
BoosTED's Avatar
Exclamation
Does your remote have the LCD with the car on it? Remote #: 2WSSR (old style
6,000' range)?
What conditions does it not respond?
Old Nov 1, 2005 | 05:35 AM
rkostolni's Avatar
I used to have one. It was the older style remote. I didn't have any complaints with it.
Old Nov 1, 2005 | 07:37 AM
moRotorMotor's Avatar
Rotary eXperimental-8
What does the LCD screen tell you anyway? I've been looking at their website and other dealers that sell Compustar alarms to get a 'bigger picture' but can't seem to find one.
Old Nov 1, 2005 | 01:57 PM
BoosTED's Avatar
It tells why the alarm is going off. ie: someone jimmys the door it alarms you with beeping and shows the car door opening. It has the tunk; hood and shows smoke coming out of the tail pipe to confirm that the car started.
Another benefit of this product is it has a turbo timer built in. It will run for 3 minutes to cool the turbo down if you want.
Old Nov 1, 2005 | 02:35 PM
jcataldo's Avatar
Program
Can you program it to start at a certin time everyday? Like 7am Monday-Friday?
Old Nov 1, 2005 | 03:11 PM
BoosTED's Avatar
Not that I can see. This could be bad though, especially if it were parked in a garage. It does have a cold start option which a person programs before leaving the vehicle. Will start every 1-3 hours, good for extreme cold days not under shelter.
The remote works really good though so as long as a person remembers to hit the buttons to start it, they will have a warm car.
Old Nov 1, 2005 | 07:36 PM
jcataldo's Avatar
Thanks for the input.
Old Dec 6, 2005 | 11:27 AM
slavearm's Avatar
Boost Junkie
IT does have a winter mode where it will start for 5 minutes every hour or so, but don't do that to your RX8
Old Dec 6, 2005 | 11:39 AM
LiL BenNy's Avatar
Bubblicious? DEF.
is there like a hold button on the remote (like cell phones) so when its in your pocket you dont like accidentaly start your car?
Old Dec 6, 2005 | 11:56 AM
slavearm's Avatar
Boost Junkie
No hold button, but to get it to start you have to hold the second button for a few seconds.
Old Dec 6, 2005 | 02:29 PM
BoosTED's Avatar
Fine this unit is made to work with manual vehicles.
Old Dec 6, 2005 | 04:25 PM
forbidden's Avatar
A compustar requires a series of events to happen in order for you to remote start the vehicle. Meaning the following.
(1) park vehicle in neutral with engine running.
(2) apply and hold foot brake.
(3) apply hand brake.
(4) release foot brake.
(5) remove keys. (vehicle is still running and therefor is not in gear)
(6) open door.
(7) close door.
At the point that the door is closed, the vehicles engine will turn off. Now the vehicle can be remote started.
**** Bonehead clause ****
If you leave your window down and reach in and put the vehicle in gear, it will start in gear, so don't be a bonehead!
Old Dec 6, 2005 | 04:43 PM
slavearm's Avatar
Boost Junkie
Hmm... I do not have those complications with my compustar for the remote start, but the turbo timer requires those EXACT sequence of events to function.
Old Dec 6, 2005 | 06:54 PM
forbidden's Avatar
To do a MANUAL transmission you do not cut the wire inside of the brain. It is usually a green wire.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Quiggs321
Sep 30, 2015 05:34 PM
pjwermuth
Sep 28, 2015 11:36 PM
